Domoticz remote question
gennapium
- Domoticz version: Stable
I have the latest beta version running om a Ubuntu 14.04 server and on a Raspberry Pi3. I have noticed that these two beta's do no have the same version. I wat to make a remote connection from the linux to the pi. But the documentation clearly says the versions have to be the same.
Could someone help me with this ?
Ubuntu server, Raspberry Pi, PiFace 2, RFXCom, Z-wave Stick, Kaku, Sensor
SweetPants
Re: Domoticz remote question
Well if the documentation says they have to be the same, you need to update one of your installationsgennapium wrote:Could someone help me with this ?
gennapium
I did update both to the latest beta version but still they are not the same versions
gennapium
Some more info,
Ubuntu is running Domoticz 3.5559
Pi3 is running Domoticz 3.5541
SweetPants
Looks like you complite fom source on one system?gennapium wrote:Ubuntu is running Domoticz 3.5559
If so, then you better compile from source to lineup your versions on both systems
- gizmocuz
Version mismatch is not relevant between these versions.
Sometimes there is an internal data structure change (last time was a half year ago), and then you need to have equal versions
What is important, is that both systems are using the same endianess (little or big endian)
gennapium
Ok great,
Now i can start buiding a new domoticz system with a remote Pi
Derik
- Domoticz version: BETA
Dear Gizmocuz..
Is it possible @ the moment to use more than 1 slave?
SweetPants
Did you search the wiki? http://www.domoticz.com/wiki/Setting_up_Device_sharingDerik wrote:Is it possible @ the moment to use more than 1 slave?
Derik
SweetPants wrote:Did you search the wiki? http://www.domoticz.com/wiki/Setting_up_Device_sharingDerik wrote:Is it possible @ the moment to use more than 1 slave?
Yep..
Only did you try to have 2 remotes....
And then??
SweetPants
Yep,Derik wrote:Only did you try to have 2 remotes....
And then??
log shows
2016-08-29 21:17:14.492 Domoticz: TCP connected to: 192.168.24.15:6144
2016-08-29 21:17:14.494 Domoticz: TCP connected to: 192.168.24.16:6144
So i tend to believe the Wiki
