basic lua script not working
easyherve
- Domoticz version: 2024.7
I really need help to understand why my BASIC LUA script is not working well.
if (otherdevices['BTN_Test'] == Off) then
print('OFF')
if (otherdevices['BTN_Test'] == On) then
print('ON')
I see on the LOG that the 2 tests are true !!! not understandable !
Thank you in advance for your help.
Regards.
print('OFF')
print('ON')
Regards.
DanM
Re: basic lua script not working
You need ' round your 'On' and 'Off'
easyherve
do you mean round(off) instead of off ?
If yes, I got an error message on the log "attempt to call global 'round' (a nil value)".
DanM
Sorry.. I should have been clearer. I mean you need 'Off' instead of Off.
Any clearer?
Any clearer?
DanM
if (otherdevices['BTN_Test'] == 'Off') then
print('OFF')
if (otherdevices['BTN_Test'] == 'On') then
print('ON')
easyherve
Hum, now both test are false .. then nothing recorded into the log except LUA:script 1!
It makes me crazy because SW_Prise_Free is a real plug device (means a boolean data) !
print('script 1')
if (otherdevices['SW_Prise_Free'] == 'Off') then
print('OFF')
if (otherdevices['SW_Prise_Free'] == 'On') then
print('ON')
return commandArray-
DanM
hmm, Im struggling to see what else is wrong (although Im sure someone else will spot it and I'll kick myself).
Just to be sure - this is a switch device? Its not a group or a scene?
EDIT: also try removing the brackets. I dont imagine this will be the cause, but you never know!
print('script 1')
if otherdevices['SW_Prise_Free'] == 'Off' then
print('OFF')
if otherdevices['SW_Prise_Free'] == 'On' then
print('ON')
easyherve
I just checked without bracket and got the same result.
It is a real switch device (everspring AN157) that works perfectly. Moreover, this device is not used into blocky or whatever, it is my "free" device.
By the way, I checked with a virtual switch and got the same result !
This is a script I program directly from EVENTS menu by choosing LUA option (means through the domoticz interface).
- Westcott
Check the reported state of the device in Events -> Show current states
easyherve
Actually, state of the device is off :
but when I switch on, it shows on in te current status but nothing change in the log.
Idx Name Current state Last updated sValues
1 SW-Lampe-Salle Off 2016-08-22 21:59:29 99
2 SW-Prise-Free Off 2016-08-23 15:24:16 0
3 SW-Leds-Cuisine Off 2016-08-22 21:59:29 99
4 SW-Leds-Salon Off 2016-08-22 21:59:29 99
5 SW-Portail Off 2016-08-22 21:08:04 0-
easyherve
I finally found the issue ! it can be consider like a bug !
Unfortunatly, all my devices are named with a dash to separate names like BTN-Test. And caracter dash into the function otherdevices['BTN-Test'] doesn't work !
so I renamed BTN-Test by BTN_Test and everything goes fine !
I am glad I found coz it starts to make me crazy
Thanks everybody !
Thanks everybody !
jmleglise
- Domoticz version: 2022.1
If this is proven, you should write this in the wiki.
My script : https://github.com/jmleglise
RFXTRX433E: Blind Somfy RTS, Portal Somfy Evolvia, chacon IO, Oregon, PIR sensor PT2262
My Last project : Location de vacances a Ouistreham vue mer
KMTronic USB relay
Chinese Z-WAVE: Neo CoolCam
KMTronic USB relay
SweetPants
You don't need to concatenate words to form a string using "_", you can also use 'BTN Test'easyherve wrote:so I renamed BTN-Test by BTN_Test and everything goes fine !
easyherve
Sure, when you know it, it is not even a topic ! but I didn't know that dash was not working into device name !
Thanks anyway for the advice
niceandeasy
- Domoticz version: 3.8153
I have devices in use with a dash in their names and they are working properly. I'm also using them in LUA scripts in ./scripts/lua. So your statement is not valid.
My devices are dummies. Yours are ZWave devices.
So the notion that dashes are not working in device names might be valid for ZWave devices, maybe it's even valid for other kinds of devices. But it's not valid for devices in general.
Another possible cause for your dash issue can be the location of your LUA scripts. They can be kept in the database / GUI, same as Blocklys. My scripts are text files in the ./scripts/lua folder of Domoticz. So where do you keep your LUA scripts?
DanM
I think he mentioned that he was using the web interface to create the Lua, could be something in the way the web-gui works that means the - gets translated incorrectly (particularily as -- comments out LUA code) ? Ive also used dashes succesfully by creating lua files directly.
