Execute Command on Log Entry
Richie1972
Post by Richie1972 »
I've had a quick look and can't see if this has been asked before.
What I want is to be able to execute a script if a particular event is flagged in the log - so, is there a way of monitoring new log entries and executing a script/command if a specific phrase/error appears?
Richie
Aeo S5 USB
3 FGSD002 Smoke
1 FGSM Motion
4 FGBS Binary
1 Horstmann ASR-ZW
2 Aeo Relay
1 FGS222 2xRelay
2 Aeo Multi Gen4
2 Everspring relay
1 Aeo Repeater
1 Popp Switch
1 TKB socket
4 Popp Dimmer
Egregius
Domoticz version: v2024.7
Re: Execute Command on Log Entry
Post by Egregius »
What do you want to look for?
And what to do with it?
Richie1972
Every so often the OpenZWave driver fails, so i need to stop Domoticz, disconnect the Aeotec USB, reconnect it and restart Domoticz.
At the moment i am not alerted to this, so would, initially, like to have an alert/email sent and, long term, automate the stop, disconnect, re-connect & restart process
Richie
Aeo S5 USB
3 FGSD002 Smoke
1 FGSM Motion
4 FGBS Binary
1 Horstmann ASR-ZW
2 Aeo Relay
1 FGS222 2xRelay
2 Aeo Multi Gen4
2 Everspring relay
1 Aeo Repeater
1 Popp Switch
1 TKB socket
4 Popp Dimmer
Egregius
Post by Egregius »
Do you have data timeout active for your zwave stick? (hardware tab)
Egregius
Post by Egregius »
Richie1972
Yes I have the time out set for thirty minutes. However, when I get the driver failure the only recovery is to disconnect and reconnect the usb controller - it just repeats the driver failure otherwise
Richie
Aeo S5 USB
3 FGSD002 Smoke
1 FGSM Motion
4 FGBS Binary
1 Horstmann ASR-ZW
2 Aeo Relay
1 FGS222 2xRelay
2 Aeo Multi Gen4
2 Everspring relay
1 Aeo Repeater
1 Popp Switch
1 TKB socket
4 Popp Dimmer
Richie1972
With regard to the link in your other message.
I can write a vbscript or even .net console app to read the file - it is just going to be difficult to check for new instances of the error.
I was hoping that there would be a way to do it in Lua similar to any other events like a switch being operated
Richie
Aeo S5 USB
3 FGSD002 Smoke
1 FGSM Motion
4 FGBS Binary
1 Horstmann ASR-ZW
2 Aeo Relay
1 FGS222 2xRelay
2 Aeo Multi Gen4
2 Everspring relay
1 Aeo Repeater
1 Popp Switch
1 TKB socket
4 Popp Dimmer
