Request,
Could you please add the SEAV TXS2 control?
I have three sunscreens with remote control that use that system.
Bert Weijenberg mailed me that RFXcom firmware 1006 has support for it.
Thanks in advance.
SEAV Implementation
Goldwing1973
- Domoticz version: Stable
SEAV Implementation
Over 50 Z-Wave Devices (Fibaro and Neo), 4xLogitech Hub, 2xPhilips Hue Bridge+55 Lights, 1x Nest Thermostat, 2xNetatmo Weather Station, 1xSkybell v1 Doorbell, 3 Kwikset KEVO Doorlocks and Domoticz running on a Intel NUC
b_weijenberg
- Target OS: -
Re: SEAV Implementation
TXS4 is supported by the RFXtrx433E but unknown if TXS2 is supported!
RFX-433, RFX-433EMC, RFX-868
Goldwing1973
Can i keep a log or something when i push the button on the remote control so you can compare the TXS4 with the control codes send by the TXS2?b_weijenberg wrote:TXS4 is supported by the RFXtrx433E but unknown if TXS2 is supported!
I also have a TXS3 and a TXS1 lying around somewhere if needed
Or is there another way to test it?
b_weijenberg
- Target OS: -
Please contact support rfxcom.com for implementation of other SEAV remotes.
Goldwing1973
I just remembered this, the RFXcom already is capable of sending the correct signal for a TXS2 remote control.b_weijenberg wrote:Please contact support rfxcom.com for implementation of other SEAV remotes.
I've tested this myself with RFXmngr 18.0.0.7, i even mailed you that it worked on 7-8-2016 at 00:07.
I'ts just that it doesn't work *yet* in Domoticz, it has to be added to Domoticz.
