Hello
Looking for a way to get zwave signal to my garage, and a way to do that is to use the mesh network . I have found and read about bulbs or sockets to put into the outlamps, but when i check the spec/datablad it seems that they are only for above 0 celsius. is there anyone with using these kinda products outdoor?
Ive found the aeonlabs which you plug in a socket, but then you only get a repeater and nothing more, and outdoor sockets are not what i have most of outside ^^
Outdoor repeater preferably light/bulb
R0yk3
Re: Outdoor repeater preferably light/bulb
leave the light on when temp drops.. keeps it above 1 degree?? otherwise pul a cat cable to your garage and make a 'domoticz slave' form a PI
Raspberry PI 3, raspbian, ZwaveMe, RFLink
Larsja
- Domoticz version: V2.3530
Yea a cat cable is an option, but was hoping for a 2in1 ^^ both light and extend the zwave network. Guess you cant have it all sometimes.
mark.sellwood
Is running CAT5 is an issue you could try power line adaptors, saves running a CAT5.
3 x Pi, 1 Master, 2 Slaves, 1x Aeotec Z-Stick S2, 4xSP103 PIR, 5xPowerNode 1, 1xSmart Energy Switch Gen5, 4xFGSS101 Smoke Sensor, 2xFGD212, 9xFGS212 , 7xFGS221/2, 1xAD142 , 1xTKB TZ68E , 2xAeotec Multi Sensor, 3 x NodOn CRC-3-1-00.
