Temperature & Humidity Sensor compatible with RFXCOM/Domoticz
Re: Temperature & Humidity Sensor compatible with RFXCOM/Domoticz
Not exactly £10, but I've found these on Amazon seller who sell them for £12, and postage is free if you buy 3 or more.
I can confirm that these are in fact Cresta-compatible, and incomparably better quality(and design) than any cheaper Chinese one you can get.
http://www.amazon.co.uk/gp/offer-listin ... dition=new
Only £ 7,70, looking better and (most likely like Cresta and Bresser etc.) of course made in China! Free shipping!
http://www.aliexpress.com/item/AOK-2011 ... 12106.html
I can confirm that these are working exactly as they should and also battery-life is fine. I do not have any complaints.
The only point I want to make is that it is old-fashioned to think that something bought on Amazon (or in a local shop) with a non-Chinese brand is made in Europe/US and therefore is better quality; most likely it is made in China and probably in the same factory.
Maybe the one with the nice English brand is made by child hands in People's Republic of Korea.
Please don’t fool yourself or others.
- leecollings
I've just been reading the reviews on this product, and there are loads of contradicting reviews from people saying it does work with Domoticz, and it doesn't. A lot of people seem to be using the RFXCOM 433E. So what's the official word?JohnBoy32 wrote:Only £ 7,70, looking better and (most likely like Cresta and Bresser etc.) of course made in China! Free shipping!
Does it work or not?
For me it works with RFXCOM 433E, raspberryPi and Domoticz; the hardware = Rubicson/IW008T/TX95.leecollings wrote:I've just been reading the reviews on this product, and there are loads of contradicting reviews from people saying it does work with Domoticz, and it doesn't. A lot of people seem to be using the RFXCOM 433E. So what's the official word?JohnBoy32 wrote:Only £ 7,70, looking better and (most likely like Cresta and Bresser etc.) of course made in China! Free shipping!
I can not speak for M***n W. from NL ..... but my guess it is not in the product itself
AWESOME! Thanks for the tip, Westcott!Westcott wrote:I got one from Banggood - it worked straight away with RFXtrx
http://www.banggood.com/433MHz-Wireless ... 8820141020
I have tried ordering several sensors from Aliexpress, but none of them have worked with RFXtrx, so this is a great tip.
Would you happen to know any cheap door sensors (magnet sensors) which also work?
I ordered the above aliexpress sensor, unfortuinately it is not picked up in the *current* firmware builds -- it looks from viewtopic.php?f=44&t=11453&p=85423#p85423 as if this is a regression, so I've emailed support
I previously had the banggood one above which continues to work fine!
Finally I also have this one but not working
With domoticz I have undec on... But don't seem to see raw data in the logs... Should I if there are some (like the aliexpress sensor)?
Hey, thanks for the good advice. I purchased some of these and they have finally arrived but I'm struggling to get domoticz/rfx433e to recognise them. What protocol do you use?JohnBoy32 wrote:Only £ 7,70, looking better and (most likely like Cresta and Bresser etc.) of course made in China! Free shipping!
Cheers
What protocol is working with these?Westcott wrote:I got one from Banggood - it worked straight away with RFXtrx
- Westcott
Sorry to be so slow in replying - I think is was Rubicson, but I'm now using RFlink, it still works perfectly.
- Target OS: -
Correct, enable Rubicson for the Banggood sensor. It will be displayed in Domoticz as a WS1700 sensor.
This is supported in the RFXtrx433E by Ext and Ext2 firmware, please see also chapter 2.2.2 in the RFXtrx User Guide
RFXtrx433, RFXtrx433E, RFXtrx433XL, RFX433XL, RFX868XL
How about the RFXtrx433? will it ever support these sensors? just got 3 because was under the impression they were supported, but on the RFXtrx433 I can't see themb_weijenberg wrote:Correct, enable Rubicson for the Banggood sensor. It will be displayed in Domoticz as a WS1700 sensor.
- Target OS: -
The Banggood sensor is only supported by the RFXtrx433E and not by the RFXtrx433 as indicated in chapter 2.2.2.
An alternative sensor is probably the Proove TSS320/TSS330
https://www.m.nu/losa-sensorer/temperat ... mpatibel-2
http://www.lohelectronics.se/elektronik ... tion=false
- sincze
- Domoticz version: 2024.4
100% True. I was the unlucky guy with the normal RFXtrx433 and did not read chapter 2.2.2b_weijenberg wrote:The Banggood sensor is only supported by the RFXtrx433E and not by the RFXtrx433 as indicated in chapter 2.2.2.
However... my RFLINK R42 deals with this sensor just fine
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
But will it ever support these sensors?... I already have 3, received them today...b_weijenberg wrote:The Banggood sensor is only supported by the RFXtrx433E and not by the RFXtrx433 as indicated in chapter 2.2.2.
Like me...sincze wrote:100% True. I was the unlucky guy with the normal RFXtrx433 and did not read chapter 2.2.2
Are you using both the rfxtrx433 and the rflink?... Or just replaced the rfxtrx with the rflink?
- sincze
heheheGusimelo wrote:Like me...sincze wrote:100% True. I was the unlucky guy with the normal RFXtrx433 and did not read chapter 2.2.2
A well we have RFXCOM for first and second floor with bigger ANTENNA directly connected via USB.
http://www.ebay.com/itm/433MHZ-10DB-SMA ... SwAL9Ui6TX
And RFLINK for second and third floor (with slightly bigger ANTENNA) connected via RFLINK LAN
http://www.ebay.com/itm/GSM-GPRS-Antenn ... xye3BRsANp
Just to cover the whole AREA
And for experimenting..... MYSENSORS Gateway now via LAN as well
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Hello JohnBoy32. Thanks for the tip.JohnBoy32 wrote:Only £ 7,70, looking better and (most likely like Cresta and Bresser etc.) of course made in China! Free shipping!
How long last the batteries in this sensor?
How many channels are available?
How are the channels configured?
Thanks.
- Domoticz version: 3.7412
Edit:
Never mind! Got it!
http://domoticz.com/forum/viewtopic.php?p=60394#p60394
How did you guys add this to domoticz? It doesn't register when pushing any button in de battery compartment.
Never mind! Got it!
Hi AllWestcott wrote:I got one from Banggood - it worked straight away with RFXtrx
- Westcott
Do you have an RFXtrx or RFlink?
- Target OS: -
Please check with RFXmngr and enable only the Rubicson/Alecto/Banggood protocol.
