Hello everyone
I want to delete a UserVariable
So I'll use the appropriate Json query.
But this query needs the Idx of UserVariable.
This variable was created with a lua script. So if another script wants to delete it, does not know its id. He only knows his name.
How can I get this Idx with his name?
Uservariable Delete
jjdom
- Domoticz version: 3.4834
Uservariable Delete
José
Domoticz raspberry pi
Version 3.4834
Version 3.4834
- Egregius
- Domoticz version: v2024.7
Re: Uservariable Delete
json.htm?type=command¶m=getuservariables gives all variables
json.htm?type=command¶m=deleteuservariable&idx=1 deletes the first
So, grab all variables, run thru the array and find the idx.
jjdom
Thanks for you help Egregius
But how to get the result of the json query, and how to grab it ?
José
Version 3.4834
Version 3.4834
- Egregius
<?php
define('api',"http://127.0.0.1:8084/");
//Grab the variables
$variables = json_decode(curl(api."json.htm?type=command¶m=getuservariables"),true);
//Check if the result isn't empty
if(!empty($variables['result'])){
//loop thru all variables
foreach($variables['result'] as $variable){
//if variable value equals ... remove it.
if($variable['Value']=="first") curl(api."json.htm?type=command¶m=deleteuservariable&idx=".$variable['idx']);
function curl($url){$headers=array('Content-Type: application/json',);$ch=curl_init();curl_setopt($ch,CURLOPT_URL,$url);curl_setopt($ch,CURLOPT_HTTPHEADER,$headers);curl_setopt($ch,CURLOPT_RETURNTRANSFER,1);curl_setopt($ch, CURLOPT_FRESH_CONNECT, TRUE);$data=curl_exec($ch);curl_close($ch);return $data;}
jjdom
Hello, Thanks for your answer,
But, I do not work in PHP, I work in LUA.
Have you a grab example in LUA?
José
Version 3.4834
Version 3.4834
