Adding to the package center is still not working.jumbotroll wrote:
DS716+II was not added on my server, but you can try again now.
How to install Domoticz on a Synology NAS
Re: How to install Domoticz on a Synology NAS
- jumbotroll
Then I don't know what the problem is.Andi80 wrote:Adding to the package center is still not working.jumbotroll wrote:
Try to manually download arch-braswell package and install manually.
https://paypal.me/Jumbotroll
Jumbotroll
http://www.jadahl.com
Jumbotroll
Hello and thank for your work. I'm spanish, sorry for my english...
Will DS216 package work for the new DS116?
- jumbotroll
Yes you can use arch-armada38xArkaitz wrote:Hello and thank for your work. I'm spanish, sorry for my english...
http://www.jadahl.com/domoticz_beta_6/?arch=armada38x
Jumbotroll
Jumbotroll
Hello again,
I have installed that package and all works well. But when I change the configuration to access with pasword, I can't login... If I insert invalid password, I have the message of invalid pass but with the correct password, the login page reloads. The logs is ok, "Login successfull from 192.168...."
Any idea?
EDIT: With internet explorer works, but with chrome don't. Caché?
Any idea?
Hey Jumbotroll,
here's a nice one... I installed last beta yesterday on synology after having used domoticz for months now and something funny happens.
The install went fine and the service shows domoticz is running, but when I try to get on the web interface it shows 'Domoticz is offline'.
Any idea where to start debugging this one?
Reboot did not change anything
Verzonden vanaf mijn iPad met Tapatalk
- jumbotroll
Check View Log on domoticz in Package Center.confucius wrote:Hey Jumbotroll,
No another reports on this problem.
Jumbotroll
Jumbotroll
jumbotroll wrote:Check View Log on domoticz in Package Center.confucius wrote:Hey Jumbotroll,
Found it, somehow it seems the default port for Domoticz has changed from 8084 to 8080. Thanks anyway!
Hi All!
I installed http://www.jadahl.com/domoticz_stable_6/?arch=armadaxp on my Synology.
I installed Package https://www.synology.com/en-us/dsm/app_packages/py3k
And now tried to adjust https://www.domoticz.com/wiki/Presence_detection_(SNMP)
1. How install SNMP on Synology https://www.domoticz.com/wiki/Presence_ ... lling_SNMP ?
2. How get "isocode" for script from my router with Windows?
3. I manually create file https://www.domoticz.com/wiki/Presence_ ... the_script , it is correct?
4. What is terminal https://www.domoticz.com/wiki/Presence_ ... executable ?
5. How install and run cron on Synology https://www.domoticz.com/wiki/Presence_ ... .28cron.29 ?
I'm only user and don't have knowledge about linux systems, so sorry for my questions.
- jumbotroll
Test package snmp (snmpwalk) for armadaxp DSM6.x
net-snmp_armadaxp-6.0_5.7.3-1.spk
http://www.jadahl.com/synology6/package ... .7.3-1.spk
Jumbotroll
Jumbotroll
Hello Jumbotroll,
Can you also add DS216+II?
- jumbotroll
DoneJohnWis wrote:Hello Jumbotroll,
Domoticz for DSM 6.0
Last edited by jumbotroll on Tuesday 27 September 2016 20:43, edited 1 time in total.
Jumbotroll
Jumbotroll
Hello Jumbotroll,
It still doesn't work to add your URL's to the Synology NAS packet sources, is there something to do for me?
John
John
- jumbotroll
I don't know why you have this problem, but did you remember to accept "Any Publisher" in package center ?JohnWis wrote:Hello Jumbotroll,
John
Jumbotroll
Jumbotroll
I have installed domoticz on my DS115, it works very fine.
Is it possible to use an Voltcraft CO-20 on the Diskstation?
it is not possible to change the port under Hardware, there is just written "USB", but it does not appear under the Devices area.
I cannot follow the instructions in the wiki ( https://www.domoticz.com/wiki/Voltcraft_CO-20 ), because apt-get is not available.
Can anybody help?
Thank you very much!
physiker123
Can anybody help?
physiker123
Hello physiker123,
I have no direct answer to your problem.
But it would be nice, if you can help me starting with Domoticz.
I also like to install Domoticz on a Synology DS115.
Did you take one of the Jumbotroll packages?
If yes, which one:
DSM 6.0 Domoticz V3.4834 Stable precompiled
DSM 6.0 beta precompiled
DSM 5.2 Domoticz V3.4834 Stable precompiled
DSM 5.2 beta precompiled
Thank you for your advice.
targetandsolution
If yes, which one:
targetandsolution
Hey,
yes I use the jumbotroll packages.
it depends which version of DSM you have and if you want to use the beta or the stable version
Greetings
Greetings
1 year ago was the last post.
i have a NAS and stil intrested in using the Domoticz
Is any one out here who can help me out?
I have a synology nas 216play
- jumbotroll
Use this if you have updated your NAS to DSM 6.x http://www.jadahl.com/domoticz_beta_6/?arch=monacogertjanwo wrote:1 year ago was the last post.
or this package if you use DSM 5.2 http://www.jadahl.com/domoticz_beta/?arch=monaco
Take a look on wiki page to https://www.domoticz.com/wiki/Synology
Jumbotroll
Jumbotroll
