I've read that Qubino has implemented a new firmware in 2RElays modules. Is the versón S5 (label is H1S5P1). Some peaople say that this module doesn't work fine.
The question: is there anybody using this switch with Domoticz? Does it show status of switch if is turned on/out by hand? Does it send consume energy reports?
New firmware from Qubino
- Domoticz version: 4.
Re: New firmware from Qubino
Nobody has this module?
Is it only available in new modules or can you update the firmware of existing modules?
Qubino doesn't allow update firmware of its modules.
S5 is the last version of firmware and I've found it when I was going to buy a new Flush 2 Relays.
And I can't find any other device like Qubino: 2 Relays, power meter, small....
