are there 868 MHZ transceivers working with domoticz
curious
Post by curious »
I cannot find a definive answer so just to be sure,
Are there 868MHZ transceivers working with domoticz ?
trixwood
Re: are there 868 MHZ transceivers working with domoticz
Post by trixwood »
If you really sure that is uses any of the RF868/RF433 protocols (we know you do not want zwave, figured that out ;-)
You can buy RFLink version
http://www.nodo-shop.nl/nl/rflink-gatew ... kabel.html
Update: Somfy RFlink forum post:
viewtopic.php?t=9318
Or an RFXCom
http://www.rfxcom.com/epages/78165469.s ... ts%2F15101
But make sure your device (the somfy or the italian(?) device) is supported!!!
Cuz you end up with a controller with nothing to talk to. Kinda waste of money.
curious
Post by curious »
Haha Trixwood, you're everywhere.
So there no such thing as learning mode for 868 Mhz devices?
Thank you for your support. I am afraid I have to use the original remote controllers.
trixwood
Post by trixwood »
Yes there is.
I would spend a little bit more time on research.
Check out:
http://www.nemcon.nl/blog2/devlist
http://www.rfxcom.com/WebRoot/StoreNL2/ ... _Guide.pdf
Not that many devices in the 868 range are supported.
And of course look through this forum (and other sites), if any other people have experience with your devices.
Then if still confused (then and only then, cuz your done your research), I would mail the support with the specific questions you have, better get your info from the pro's instead of some forum post guy :o
RFXCom support email: [email protected]
RFLink support email: [email protected]
