Import data from Fronius Solar api
videodrome
Is there a script that allows to import in domoticz the data of production via solar API?
trixwood
Re: Import data from Fronius Solar api
did you try the search? Like search for "Fronius"? You know the upper right corner?
http://domoticz.com/forum/viewtopic.php ... it=Fronius
videodrome
I read it, but......trixwood wrote:did you try the search? Like search for "Fronius"? You know the upper right corner?
1) I don't want to install emoncms, feed data to this and then pass them to domoticz. I'd like to transfer them in real time directly from the inverter to domotic via solar API call. I am actually downloading data from the inverter (using the Fronius push service) to PVoutput which feeds domoticz. The problem is that the push service sends data every five minutes, so I can't have the production data in real time into domoticz.
2) if I launch a http request like this"http://192.168.x.xxx./solar_api/v1/GetI ... verterData" I get a json file with all the readings in real time. II think it is possible to feed a virtual sensor with this data, but how?
- Egregius
- Domoticz version: v2024.7
Your inverter has a json api interface?
Run a script that pulls that json, decode it and push it to domoticz to a virtual solar device.
Is you post a json example I can create a php script for you.
I do something similar but my data comes from a csv that's updated every minute. Once the value is in Domoticz I use it to decide if lights need to switch on and stuff like that.
videodrome
Yes, my fronius inverter supports json Api interface.Egregius wrote:Your inverter has a json api interface?
Tomorrow, when the inverter is active, i'll post the json reply from the http request.
Thanx
videodrome
Below the reply from the api call:Egregius wrote:Your inverter has a json api interface?
http://192.168.X.XXX/solar_api/v1/GetIn ... verterData
PAC is the value of AC power generated in real time
"Head" : {
"RequestArguments" : {
"DataCollection" : "CommonInverterData",
"DeviceClass" : "Inverter",
"DeviceId" : "1",
"Scope" : "Device"
"Status" : {
"Code" : 0,
"Reason" : "",
"UserMessage" : ""
"Timestamp" : "2016-07-24T18:22:14+02:00"
"Body" : {
"Data" : {
"DAY_ENERGY" : {
"Value" : 17710,
"Unit" : "Wh"
"FAC" : {
"Value" : 50,
"Unit" : "Hz"
"IAC" : {
"Value" : 2.56,
"Unit" : "A"
"IDC" : {
"Value" : 1.8,
"Unit" : "A"
"PAC" : {
"Value" : 570,
"Unit" : "W"
"TOTAL_ENERGY" : {
"Value" : 507147.03,
"Unit" : "Wh"
"UAC" : {
"Value" : 231.5,
"Unit" : "V"
"UDC" : {
"Value" : 345.9,
"Unit" : "V"
"YEAR_ENERGY" : {
"Value" : 507147.72,
"Unit" : "Wh"
"DeviceStatus" : {
"StatusCode" : 7,
"MgmtTimerRemainingTime" : -1,
"ErrorCode" : 0,
"LEDColor" : 2,
"LEDState" : 0,
"StateToReset" : false
- Westcott
There are many examples on this forum showing how to read JSON data directly with Lua, and update virtual devices.
- Egregius
create a file /home/pi/solar.php
make it executable:
chmod +x /home/pi/solar.php
add the script to cron (crontab -e)
* 7-23 * * * /home/pi/solar.php
That's every minute between from 7 till 23.
#!/usr/bin/php
<?php
$data = json_decode(file_get_contents('http://192.168.x.xxx/solar_api/v1/GetInverterRealtimeData.cgi?Scope=Device&DeviceID=1&DataCollection=CommonInverterData'),true);
if(isset($data['Body']['Data']['PAC']['Value'])) {
file_get_contents('http://127.0.0.1:8084/json.htm?type=command¶m=udevice&idx=412&nvalue=0&svalue='.$data['Body']['Data']['PAC']['Value']);
videodrome
i can't execute the script. I create the php file and changed the idx number of my sensor, the ip number and port of domoticz, added the scripts to crontab and maked executable with chmod, but nothingEgregius wrote:create a file /home/pi/solar.phpmake it executable:Code: Select all
#!/usr/bin/php <?php $data = json_decode(file_get_contents('http://192.168.x.xxx/solar_api/v1/GetInverterRealtimeData.cgi?Scope=Device&DeviceID=1&DataCollection=CommonInverterData'),true); if(isset($data['Body']['Data']['PAC']['Value'])) { file_get_contents('http://127.0.0.1:8084/json.htm?type=command¶m=udevice&idx=412&nvalue=0&svalue='.$data['Body']['Data']['PAC']['Value']); }
The attributes of php file are correct?
-rwxr-xr-x 1 pi pi 395 Jul 26 19:14 solar.php.
#!/usr/bin/php
<?php
$data = json_decode(file_get_contents('http://192.168.1.103/solar_api/v1/GetInverterRealtimeData.cgi?Scope=Device&DeviceID=1&DataCollection=CommonInverterData'),true);
file_get_contents('http://192.168.x.xxx:8080/json.htm?type=command¶m=udevice&idx=58&nvalue=0&svalue='.$data['Body']['Data']['PAC']['Value']);
- Egregius
Add a line like this to see if php is ok:
echo 'test';
And also add echo in front of the file_get_contents of the udevice command to see the reply of domoticz.
Otherwise there's no output.
echo 'test';
videodrome
the first echo test is ok but the second echo on the line of "file_get_contents" is negative...
- Egregius
Can you post the output of this:
#!/usr/bin/php
<?php
echo 'test 1';
print_r($data);
echo 'test 2';
echo 'PAC='.$data['Body']['Data']['PAC']['Value'];
videodrome
yess, we are, now the sensor read the output.
1 read only, when i launched the script in putty. I added the php file in crontab, but it doesn't seems to work
Is it possible to add the DAY ENERGY and the TOTAL ENERGY in the script? Thanx in advance
test 1Array
[Head] => Array
[RequestArguments] => Array
[DataCollection] => CommonInverterData
[DeviceClass] => Inverter
[DeviceId] => 1
[Scope] => Device
[Status] => Array
[Code] => 0
[Reason] =>
[UserMessage] =>
[Timestamp] => 2016-07-27T19:16:46+02:00
[Body] => Array
[Data] => Array
[DAY_ENERGY] => Array
[Value] => 18862
[Unit] => Wh
[FAC] => Array
[Value] => 49.98
[Unit] => Hz
[IAC] => Array
[Value] => 1.03
[Unit] => A
[IDC] => Array
[Value] => 0.67
[Unit] => A
[PAC] => Array
[Value] => 196
[Unit] => W
[TOTAL_ENERGY] => Array
[Value] => 572775
[Unit] => Wh
[UAC] => Array
[Value] => 219.1
[Unit] => V
[UDC] => Array
[Value] => 351.4
[Unit] => V
[YEAR_ENERGY] => Array
[Value] => 572775.44
[Unit] => Wh
[DeviceStatus] => Array
[StatusCode] => 7
[MgmtTimerRemainingTime] => -1
[ErrorCode] => 0
[LEDColor] => 2
[LEDState] => 0
[StateToReset] =>
- Egregius
It isn't very hard to add more values, just walk thru the array:
I always put a microsleep of 1/4 sec between commands, just to not stress the system to much.
I also added a logfile (make sure /var/log is writable for the user that runs the script) to check if it runs in cron.
#!/usr/bin/php
<?php
print_r($data);
$result = file_get_contents('http://192.168.x.xxx:8080/json.htm?type=command¶m=udevice&idx=58&nvalue=0&svalue='.$data['Body']['Data']['PAC']['Value']);
logwrite($result);
usleep(250000);
$result = file_get_contents('http://192.168.x.xxx:8080/json.htm?type=command¶m=udevice&idx=59&nvalue=0&svalue='.$data['Body']['Data']['DAY_ENERGY']['Value']);
logwrite($result);
usleep(250000);
$result = file_get_contents('http://192.168.x.xxx:8080/json.htm?type=command¶m=udevice&idx=60&nvalue=0&svalue='.$data['Body']['Data']['TOTAL_ENERGY']['Value']);
logwrite($result);
function logwrite($msg) {
$time = microtime(true);
$dFormat = "Y-m-d H:i:s";
$mSecs = $time - floor($time);
$mSecs = substr(number_format($mSecs,3),1);
$fp = fopen(/var/log/fronius.log,"a+");
fwrite($fp, sprintf("%s%s %s %s\n", date($dFormat), $mSecs, $msg));
fclose($fp);
videodrome
I also added a logfile (make sure /var/log is writable for the user that runs the script) to check if it runs in cron.[/quote]
I changed the owner (pi) to the log folder and add the permission to be writable (700) at the owner. Is it correct?
but when i launch the php file it says
HP Parse error: syntax error, unexpected '/' in /home/pi/solar.php on line 21
videodrome
drwx------ 10 pi pi 4096 Jul 28 00:56 logHP Parse error: syntax error, unexpected '/' in /home/pi/solar.php on line 21
- Egregius
Oh, forgot to quote the logfile.
Must be
$fp = fopen('/var/log/fronius.log',"a+");
Must be
videodrome
the script works on all 3 sensor.Egregius wrote:Oh, forgot to quote the logfile.
Must be
I have this warnirng the the end of the script
PHP Warning: sprintf(): Too few arguments in /home/pi/solar.php on line 22
PHP Warning: sprintf(): Too few arguments in /home/pi/solar.php on line 22the crontab seems correct....
# For example, you can run a backup of all your user accounts
# at 5 a.m every week with:
# 0 5 * * 1 tar -zcf /var/backups/home.tgz /home/
# For more information see the manual pages of crontab(5) and cron(8)
# m h dom mon dow command
* 7-24 * * * /home/pi/solar.php- Egregius
Didn't test the code, copied from my script and stripped the unneeded stuff, sorry for the errors. There's a %s to much in the sprintf line.
I always run scripts as root (sudo crontab -e)
Never used a user crontab, don't even know if that's executed without being logged in.
Also, maybe test with chmod 755 solar.php
Was there a logfile after running manually?
#!/usr/bin/php
<?php
print_r($data);
logwrite($result);
usleep(250000);
logwrite($result);
usleep(250000);
logwrite($result);
fwrite($fp, sprintf("%s%s %s\n", date($dFormat), $mSecs, $msg));
fclose($fp);
videodrome
Now the script works well, thanx.
I ask you for an advice on another php script already running.
The script below, reads from a meter (eastron sdm 220 c) under rs485 modbus.
All the readings works well.
I'd like to import the reading of the energy imported (-i).
I entered in line n. 5 -i for reading, and at the bottom of the file the reference to the idx n.44 for the reading of imported energy. When I restart the script I find inverted the two readings ( exported on 44 and imported on 43 ) Why ?
#!/usr/bin/php
<?php
$data = array();
inizio:
$x = exec("/usr/local/bin/sdm120c -v -c -p -g -f -e -i -t -q -w3 -z5 /dev/ttyUSB0");
$data = preg_split('/[[:space:]]+/', $x);
if ($data[8] = 'OK') {
$tensione = $data[0];
$corrente = $data[1];
$potenza = $data[2];
$cosfi = $data[3];
//$frequenza_2 = $data[4];
$immessa = $data[5];
$prelevata = $data[6];
$energia = $data[7];
$ch = curl_init();
curl_setopt($ch, CURLOPT_URL, "http://192.168.X.XXX:8080/json.htm?type=command¶m=udevice&idx=1&nvalue=0&svalue=$tensione");
$oem = curl_exec($ch);
curl_close($ch);
$ch = curl_init();
curl_setopt($ch, CURLOPT_URL, "http://192.168.X.XXX:8080/json.htm?type=command¶m=udevice&idx=2&nvalue=0&svalue=$corrente");
curl_close($ch);
$ch = curl_init();
curl_setopt($ch, CURLOPT_URL, "http://192.168.X.XXX:8080/json.htm?type=command¶m=udevice&idx=3&nvalue=0&svalue=$potenza;$energia");
curl_close($ch);
$ch = curl_init();
curl_setopt($ch, CURLOPT_URL, "http://192.168.X.XXX:8080/json.htm?type=command¶m=udevice&idx=4&nvalue=0&svalue=$cosfi");
curl_close($ch);
$ch = curl_init();
curl_setopt($ch, CURLOPT_URL, "http://192.168.X.XXX:8080/json.htm?type=command¶m=udevice&idx=43&nvalue=0&svalue=$immessa");
curl_close($ch);
$ch = curl_init();
curl_setopt($ch, CURLOPT_URL, "http://192.168.X.XXX:8080/json.htm?type=command¶m=udevice&idx=44&nvalue=0&svalue=$prelevata");
curl_close($ch);
//sleep(2);
goto inizio;
