yesterday I tried RFlink with Domoticz on Raspberry Pi3, but without success: I didn't see any devices recognized in Domoticz ( I have a PIR sensor and a temperature an humidity sensor). Then I tried with Rflink with RFlink loader v1.08, this is the log window:
20;00;Nodo RadioFrequencyLink - RFLink Gateway V1.1 - R42;
10;version;
20;01;VER=1.1;REV=42;BUILD=0a;
10;rfdebug=on;
20;02;RFDEBUG=ON;
10;ping
10;ping
So I think that the RFlink doesn't work, what do you suggest? may be the problem is the arduino clone?
I have a Robotdyn Mega CH340/ATmega2560 and a RFlink gateway with Aureal tranceiver by NODO-Shop
I really appreciate any help you can provide.
RFLink support
- Domoticz version: 3.9227
RFLink support
Domoticz + Mysensors 2.0 ESP8266 GW + RFlink + Philips Hue 2.0 + Netatmo Thermostat
- Stuntteam
Re: RFLink support
You can contact me directly via [email protected] for support...
Re: RFLink support
Hello! thanks Stuntteam but I find the solution: a wire between GND pin on Arduino and GND pin on RFLink PCBStuntteam wrote:You can contact me directly via [email protected] for support...
I don't know if this is a well known rule or not...
- Stuntteam
Re: RFLink support
the rflink pcb has seperate ground and vcc connections.. no additional wires shoudl be needed.
Unless you did not solder those points.
