Pilot: Home Automation Control (iOS app)
Flopp
Re: Pilot: Home Automation Control (iOS app)
Post by Flopp »
Another Location related problem. If I activate Geofence and type a city, Stockholm, then delete the whole word and press Done Pilot will crash
Flopp
Post by Flopp »
Question: if I click on settings, bottom right, shall I come directly to Server settings?
hjvingen
Post by hjvingen »
Flopp wrote:I have issue with location service settings.
When I enter the settings and want to go back I have to press BACK two times
Latest Beta, Swedish language.
Feature? Why can I select a Temperature sensor as Switch in Location Services? Can you filter out everything else except Switch?
Location service works OK, did look if I'm not always get the "leave" message, but last two days it worked.
I have the same issue with the settings menu (Dutch language)
- When I open the settings menu the first time it opens in the server settings.
- When opening the location services, it looks like it opens this menu twice.
At the second instance there is a back button in the top left, when I press it I get back to the first instance of the location settings screen. but here there is a back to "settings" button in the top left. With this button I get back to the settings screen.
Nautilus
Post by Nautilus »
great to have the selector switches on the new version, was really looking forward for having them, also on the today widget :) One issue I have noted though. If "hide 'off' level" is enabled in the selector switch options, Pilot is still showing it and for some reason throws of the "Set Level" off by +10. E.g. if I have a switch with 5 levels (and "Off" is hidden), if I click on option 5 which should be setting level to 50, Pilot tries to set it to level 60 (which apparently causes all sorts of other problems in Domoticz, I was able to even crash it once before I noticed this :lol: ). If "Off" level is left visible, it works as expected.
ben53252642
Post by ben53252642 »
Really like this app, thanks so much for creating it!
In particular I like that it can also do the push notifications. :D
martk
Post by martk »
Since the last update from 6-7 it won't open anymore on my friends Iphone 5s
When he starts the app, the pilot logo appears and after 2 seconds you're back on the home screen.
I'm not sure but I think he has his ios updated.
johnvl
Post by johnvl »
martk wrote:Since the last update from 6-7 it won't open anymore on my friends Iphone 5s
I had the same problem with one iPhone 4s. After updating iOS to the latest version the problem was gone!
Hope this helps you also.
patoo77
Post by patoo77 »
Hi everyone,
1.8.0 version of Pilot crashes for iOS 8 users. Updating a fix as we speak.
Sorry for the inconvenience!
Nautilus
Post by Nautilus »
Nautilus wrote:Hi,
Found another repeatedly occuring issue with the latest version. Re-ordering favorites does not work consistently. At some point when opening the app again the favorites will go into some old (or random, not sure) order and stay that way until I re-order them again. Then after a little while, the same thing happens again. I have iPhone6 with latest iOS.
patoo77
Post by patoo77 »
1.8.1 is out: fixes bunch of bugs you guys reported. ;)
Also, it now works again on iOS 8, that's a biggy!
Let me guys know what you think!
essayer
Post by essayer »
Hi Patrick
Great app - use it every day.
I'm just interested to know whether you plan to integrate Pilot with MyDomoticz?
I prefer not to expose my server to public IP, so it seems a good way to get location services working.
patoo77
Post by patoo77 »
essayer wrote:Hi Patrick
I will, as soon as the mydomoticz service is compatible with apps.
I regularly ask their team about app support, but at the moment it's just not available. :/
Be sure I'll be sure the first one to add support for it when it's available! ;)
marton
Domoticz version: v3.8235
Post by marton »
I've been using this app and loving it!
However Since the 1.8.1 update I cannot connect to domoticz from my 4G connection. The local connect through wifi works, but not the other. Did you guys experienced something like this?
Kroontje
Post by Kroontje »
Same for my girlfriends phone, iPhone 6s with iOS 9.3.2.. no connection anymore through 4G or WiFi to the outside address.. :( internal server works fine when on WiFi
schulpr
Post by schulpr »
Kroontje wrote:Same for my girlfriends phone, iPhone 6s with iOS 9.3.2.. no connection anymore through 4G or WiFi to the outside address.. :( internal server works fine when on WiFi
Me 2!
Kroontje
Post by Kroontje »
Some extra info, my phone a iPhone 6s with iOS 10 public beta 2 and the Pilot 1.8 BETA 2 version works flawless..
I do not update the Pilot app to the final version right now, need the external connection for geofencing..
amz4u2nv
Post by amz4u2nv »
I am having issues with connecting in 4g... but I think the reason is because ssl doesn't work anymore correctly.
Anyone else having issues with ssl not working on the pilot app?
patoo77
Post by patoo77 »
SSL was broke in 1.8.1
1.8.2 is out in the AppStore and fixes this very issue.
Hopefully it should all be good now, sorry again for these issues. :/
Let me know how the update goes!
marton
Post by marton »
Great! Thank you. Works like a charm after the update.
Kroontje
Post by Kroontje »
Yep, thanks for the quick fix! :D
