syslog question
jannl
Domoticz version: 2025.5.x
syslog question
Post by jannl »
I enabled the syslog option in the Domoticz startfile.
The only entry I see in the logfile is the starting and stopping of Domoticz.
Is this normal behaviour for the stable 3.4834
gizmocuz
Re: syslog question
Post by gizmocuz »
it also does not report any errors (if there are errors?)
jannl
Re: syslog question
Post by jannl »
Hm, not sure. I will check tonight
bizziebis
Domoticz version: 3.8805
Re: syslog question
Post by bizziebis »
I use syslog for a long time with these daemon arguments:
"$DAEMON_ARGS -daemon -www 80 -loglevel 0 -syslog local1"
It's working just fine.
hansrune
Re: syslog question
Post by hansrune »
+1 on ok. Must be combined with -daemon to take effect.
jannl
Re: syslog question
Post by jannl »
I am on stable, the local1 option is not in the stable at the moment (when I am correct).
@gizmocuz: no errors are present in syslog, but present in the domoticz log
shkaff
Domoticz version: Stable
Re: syslog question
Post by shkaff »
I use the same stable version.
And I have the same problem = all variants of -syslog local0...local7 settings are ignored
Instead, some logging info is fragmented across
facility 1 (/var/log/user.log & syslog):
Domoticz is starting up....
Domoticz running...
Domoticz is exiting...
Domoticz stopped...
facility 3 (/var/log/daemon.log & syslog):
Starting LSB: Home Automation System...
Domoticz V3.4834 (c)2012-2016 GizMoCuz
Build Hash: 8398125, Date: 2016-03-02 10:43:51
Started LSB: Home Automation System.
System: Raspberry Pi
Startup Path: /home/pi/domoticz/
Stopping LSB: Home Automation System...
Stopped LSB: Home Automation System.
I configured mosquitto for syslog local5 and I have all its messages logged properly as facility 21
Something is wrong about that in this stable version
