I was hoping someone could help me find some cheap sockets -
Does anyone know if these would work -
https://www.amazon.co.uk/Energenie-MIHO ... B019IBT7R8
with rfxtrx433E/rfxtrx433 and domoticz.
Thanks,
Amit
Energenie
georgesattali
Re: Energenie
as I understand it, the MIHO039 is a kind to equivalent to the package "raspberry+rfxcom", but you cannot install domoticz on it.
Rather you have to download the "Mi|Home App" on your phone - the "Mi|Home App" is "a kind of" domoticz app, but probably with much less support an forum.
my advice : cheap sockets (range up to 10 - 15 meters) => https://www.amazon.fr/gp/product/B008YS ... UTF8&psc=1
is that what you're looking for ?
maybe take more advice on the forum. Those chacon (I have) work with rflink.
Good evening, GD
Good evening, GD
- gizmocuz
Re: Energenie
Why dont you have a look at 'klikaanklikuit' (or coco in english)
http://www.klikaanklikuit.nl/shop/nl/producten/sets/
Works perfectly with the rfxtrx433(e)
amz4u2nv
Re: Energenie
Thanks for the suggestions, but I am looking for inbuilt sockets like these -
https://www.bigondiy.co.uk/megaman-ligh ... oCSmXw_wcB
Have you found anything like these that are compatiable with rfxtrx?
- Marci
- Domoticz version: 3.8153
Energenie
The energenie sockets in the OP are Coco GDR2 compliant and work fine with rfxtrx433e. You just manually add your switches in Domoticz as Coco GDR2, put the sockets (one at a time) into learn mode, then hit the on/off switch in Domoticz that you wish to control that particular socket. Socket then pairs to that Domoticz switch - done.
You only need the sockets, not the MiHome hub.
Extended Domoticz homebridge-plugin for latest Homebridge - adds temp/humidity/pressure sensors, power consumption sensors, DarkSkies virtual weather station support, YouLess Meter support, general % usage support & switch/lamp status checking!
