Domoticz not executing script, putty is.
fransiefrans
Domoticz version: stable
Re: Domoticz not executing script, putty is.
Post by fransiefrans »
sudo  /home/pi/domoticz/scripts/bash/deurbel.sh
doesn't work anymore
sh  /home/pi/domoticz/scripts/bash/deurbel.sh
is working
jannl
Domoticz version: 2022.2
Post by jannl »
Looks like the script is not executable anymore or the shebang line is wrong or missing.
fransiefrans
I still can't figure out what the problem could be.
jvdz
Domoticz version: 4.107
Post by jvdz »
It's for me not totally clear what is and what isn't working but looking at the posted info I would suggest to try in your lua script:
os.execute("sh /home/pi/domoticz/scripts/bash/deurbel.sh &")
and from the commandline for the sudo version:
sudo  sh /home/pi/domoticz/scripts/bash/deurbel.sh
Jos
fransiefrans
from commandline result:
pi@raspberrypi:~$ sudo  sh /home/pi/domoticz/scripts/bash/deurbel.sh
Hallo
--2016-07-14 21:16:10--  http://192.168.2.1:8080/camsnapshot.jpg?idx=1
Connecting to 192.168.2.1:8080... connected.
HTTP request sent, awaiting response... 200 OK
Length: 303356 (296K) [image/jpeg]
Saving to: ‘STDOUT’
-                   100%[=====================>] 296.25K  --.-KB/s   in 0.008s
2016-07-14 21:16:11 (34.2 MB/s) - written to stdout [303356/303356]
<html>
<head><title>302 Found</title></head>
<body bgcolor="white">
<center><h1>302 Found</h1></center>
<hr><center>nginx/1.10.0</center>
</body>
</html>
jvdz
Post by jvdz »
What happens when you use the url in a browser on your computer?
Scratch that.. it looks like it downloads the image. So what is returning that HTML information?
Jos
fransiefrans
jannl wrote:yes, that should work. (I assume the declaration of commandArray is present).
In the deurbel.sh script, all needed variables need to be declarared/initialised
I don't understand what Jannl is saying. what should I change?
deurbel.sh:
#!/bin/sh
echo "Hallo"
#SendMsgTo=$1
SendMsgTo=$TelegramChatId
IP="192.168.2.2"                              # IP address Camera
SnapFile=$TempFileDir"snapshot.jpg"
if ping -c 1 $IP > /dev/null ; then  # if IPCAM is online then:
     wget -O - http://192.168.2.1:8080/camsnapshot.jpg?idx=1 > $SnapFile
   sleep 2
   curl -s -X POST "https://api.telegram.org/bot"$TelegramBotToken"/sendPhoto" -F chat_id=$SendMsgTo -F caption="er wordt aangebeld" -F photo="@$SnapFile"
   curl --data 'chat_id='$SendMsgTo --data-urlencode 'text=IP-cam niet beschikbaar.' 'https://api.telegram.org/bot'$TelegramBotToken'/sendMessage'
fi
fransiefrans
when I type http://192.168.2.1:8080/camsnapshot.jpg?idx=1 in my browser, it is downloading the snapshot
fransiefrans
what do you mean with HTML information?
is sending me a snapshot to telegram
jvdz
Post by jvdz »
Ok, so the Wget is working but the Telegram isn't. Just update the script from:
to this which will echo the commandline to the console:
echo curl -s -X POST "https://api.telegram.org/bot"$TelegramBotToken"/sendPhoto" -F chat_id=$SendMsgTo -F caption="er wordt aangebeld" -F photo="@$SnapFile"
This should show you whether all components in the url are filled in correctly.
Jos
fransiefrans
nothing has changed.
I tried it in commandline
working showing me the same results
not working showing me this:
pi@raspberrypi:~$ sudo  /home/pi/domoticz/scripts/bash/deurbel.sh
Hallo
--2016-07-14 21:43:51--  http://192.168.2.1:8080/camsnapshot.jpg?idx=1
Length: 299897 (293K) [image/jpeg]
Saving to: ‘STDOUT’
-                                       100%[==============================================================================>] 292.87K  --.-KB/s   in 0.01s
2016-07-14 21:43:52 (24.6 MB/s) - written to stdout [299897/299897]
curl -s -X POST https://api.telegram.org/bot/sendPhoto -F chat_id= -F caption=er wordt aangebeld -F [email protected]
<html>
</body>
</html>
it used to work with sudo command. but even then the script never worked in domoticz on/off.
and in on/off action in domoticz, it appears in the log that it is executing the script but no snapshot is send.
jvdz
Post by jvdz »
As you can see the details of the environment variables are missing on the URL when ran with Sudo.
you will see the difference when you run: env | grep Tele
and: sudo env | grep Tele
Jos
fransiefrans
env | grep Tele is giving me telegrambotoffset, token and chat id
sudo env | grep Tele is giving me nothing
what is the difference between sudo and sh executing a file?
jvdz
Post by jvdz »
When shelling it without sudo it runs with USER pi.
When shelling with sudo it runs with USER root.
So guess by default the script to set the environment variables (/etc/profile.d/DomoticzData.sh) is ran with the pi userid.
Why do you need/want to use sudo anyways?
Jos
fransiefrans
Ok that's clear to me now.
I don't need to use sudo. I need it to work with on/off action in domoticz :D
jannl
Post by jannl »
Are all the variables declared. They must be declared inside the proces space of the script.
For instance are you sure the scripts knows the value of $TelegramChatid?
fransiefrans
Re: RE: Re: Domoticz not executing script, putty is.
jannl wrote:Are all the variables declared. They must be declared inside the proces space of the script.
Jannl was right. With perfect help from jvdz my issue has been solved. The solution was to alter the script by declaring the variables in the top.
#!/bin/sh
TelegramBotToken="123456789:AAAAAAAAAAAAA_22222222222"
TempFileDir="/var/tmp/"
SendMsgTo="12345678"
   sleep 2
fi
