Hi There,
i have an problem/idea and i haven't got it to work so hopefully it will with your help.
I am trying to create virtual switches with the json API but i also want to change the Image field and the strParamter fields.
I know that the strings in the StrParam1 and StrParam2 are base64 encoded so that is not the problem but i can't find where i can change the values using the API.
Does anyone has any idea's about this?
Greetings,
Squandor
Add Virtual Switch with parameters Json API
