Second controller / second domoticz
willie-p
Post by willie-p »
I'm struggling with something what I wanted to do for some time.
When I started using domoticz I tried to get it running on a pi with razberry including xbmc. Unfortunately it did't work in that setting so I migrated to windows server with an aeon stick.
I would like to use my pi for domoticz due to the fact I bought a new version for kodi.
Summarized:
Currently primary domoticz on windows with a eaon stik.
Would like to have the secondary domoticz on the older pi with razberry, including the zwave network I have on the primary.
Is this possible? Or is this only possible by creating a new network...
Kind regards,
Will
Doomotic
Domoticz version: 2.3530
Re: Second controller / second domoticz
Post by Doomotic »
willie-p
Post by willie-p »
Thank you very much for the wiki link doomotic, however it is not exactly what I'm looking for.
The device sharing and the commands still goes via the primary domoiticz, what I'm looking for is a way to replicate the specific zwave configuration and devices so I've a redundant system.
Kind regards,
Will
leby
Post by leby »
On the hardware config for your pi just choose receive configuration from other controller. At the same time you set your Windows system in unclouded mode. You will then end up with the pi as secondary controller that can act independently from the Windows system
/lennart
willie-p
Post by willie-p »
Thank you very much leby!
I'm trying to send my configuration from my windows controller and choose receive configuration at my pi, however it doesn't work.
Pi log mentions:
2016-01-29 19:43:42.357 OpenZWave: Command is starting
2016-01-29 19:43:42.364 OpenZWave: Receive Configuration initiated...
2016-01-29 19:43:52.375 OpenZWave: Received timeout notification from HomeID: 3332359648, NodeID: 255 (0xff)
2016-01-29 19:43:52.376 OpenZWave: Command invocation had error(s) and was aborted, Error: Failed
Windows log:
2016-01-29 19:43:35.443 OpenZWave: Replication to Secondary Controller initiated...
2016-01-29 19:43:35.444 OpenZWave: Command is starting
2016-01-29 19:43:35.450 OpenZWave: Waiting for User action...
2016-01-29 19:44:05.178 ZWave: Stopping Controller command (Timeout!)
Kind regard,
Will
sj3fk3
Post by sj3fk3 »
Did you ever get to fix this? I'm trying the exact same thing (2 pi's one with a usb z-wave stick, the other with a razberry).
willie-p
Post by willie-p »
sj3fk3 wrote:Did you ever get to fix this? I'm trying the exact same thing (2 pi's one with a usb z-wave stick, the other with a razberry).
Unfortunately not.
Did try it many times.....and gave up.
Heursqem
Post by Heursqem »
Same problem here
Anyone who found solution for this?
Heursqem
Post by Heursqem »
so, at the receiving site I push the button "receive configuration from other controller"
The log shows the following error
2016-06-30 21:53:55.564 OpenZWave: Command is starting
2016-06-30 21:53:55.568 OpenZWave: Receive Configuration initiated...
2016-06-30 21:54:05.570 OpenZWave: Received timeout notification from HomeID: 3575595134, NodeID: 255 (0xff)
2016-06-30 21:54:05.571 OpenZWave: Command invocation had error(s) and was aborted, Error: Failed
Strange as there is no NodeId 255
