I have 10 of the remote control Mercury switches that have been in the rfxcom instructions for a while. They work really well under the rfxcom Windows manager app. I realise they are probably not a common item but might it be possible to add a more generic switch that would allow the setting of a complete on and off string in much the same way as the manager has a test text box?
Apologies if this is already in place,
Lighting4 Mercury switch from RFXtrx433E
RFXtrx433E
Raspberrypi 2
MAX EQ3
GPIO
Homeeasy
Mercury
CumulusMX
Raspberrypi 2
MAX EQ3
GPIO
Homeeasy
Mercury
CumulusMX
Re: Lighting4 Mercury switch from RFXtrx433E
hi I picked up Mercury switches (Model 350.115) on Amazon figuring they would be compatible. Unfortunately, I've enabled all the modes on the RFXtrx433E and as of firmware 1005 they are NOT. Guess I will have to return them
They were on a good deal and work fine otherwise... oh well
setup: Domoticz@SynNAS; RFXTRX 433; Response E. Alarm, Teqin IP PTZ Camera, Mercury Socket, 1byOne Chime; SSE smart meter
plan: Lightwave RF Dimmers & PIR, integ. evohome heating
working now! - http://www.domoticz.com/forum/viewtopic ... 549#p89549
