when not sure where to post, post here and mods will move it to right forum .
Moderators: leecollings , remb0
Flopp
Posts: 279 Joined: Sunday 03 January 2016 14:55
Post
by Flopp » Friday 24 June 2016 10:26
I get this message in Log
2016-06-24 10:20:10.245 Error: EventSystem: Warning!, lua script larmstatus has been running for more than 10 seconds
2016-06-24 10:20:10.265 LUA: Ping failed
What I want to do is to Ping the Pi that handle the CGI and if Ping is not successful I want the script to exit.
This is my script
ping_success=os.execute('ping -c1 192.168.xxx.xxx')
if ping_success then
print("ping success")
time = os.date("%Y-%m-%d %H:%M:%S")
json = (loadfile "/home/pi/domoticz/scripts/lua/JSON.lua")()
file = io.open("larm.txt", "a")
file:write(time.."\n")
local visonic=assert(io.popen('curl http://192.168.xxx.xxx/cgi-bin/jsongetxplstate.cgi'))
file:write("curl ok\n")
local status = visonic:read('*all')
visonic:close()
if status == "" then
--print("h")
file:write("empty\n")
file:write(status.."\n")
--print (status)
local jsonStatus = json:decode(status)
print (jsonStatus)
--file:write(jsonStatus.."\n")
powermaxstatus = jsonStatus['pmaxstatus']
--print(powermaxstatus)
--print(otherdevices['Visonic Alarm Status'])
if (powermaxstatus == "disarmed" or powermaxstatus == "armed" or powermaxstatus == "armed-home" or powermaxstatus == "armed-away") then
if powermaxstatus == "disarmed" and otherdevices['Visonic Alarm Status'] == "On" then
print('<font color="blue">Visonic: Larmat av</font>')
commandArray['Visonic Alarm Status'] = "Off"
commandArray[1]={['SendEmail']='Avlarmat# #[email protected] '}
--commandArray[2]={['SendEmail']='Avlarmat# #[email protected] '}
if (powermaxstatus == "armed" or powermaxstatus == "armed-home" or powermaxstatus == "armed-away") and otherdevices['Visonic Alarm Status'] == "Off" then
print('<font color="red">Visonic: Larmat på</font>')
commandArray['Visonic Alarm Status']='On'
commandArray[1]={['SendEmail']='Pålarmat# #[email protected] '}
--commandArray[2]={['SendEmail']='Pålarmat# #[email protected] '}
file:close()
print('<font color="red">Ping failed</font>')
jannl
Posts: 872 Joined: Thursday 02 October 2014 6:36
Domoticz version: 2026.1.x
Post
by jannl » Friday 24 June 2016 10:40
Seems the script runs too long. You could add a timeout to the ping. No need to wait several seconds for a ping reply that will not come. Ping in local network is like milliseconds...
Flopp
Post
by Flopp » Friday 24 June 2016 10:45
Yes it runs more than 10 seconds but a Ping should be maximum 1 second according to Domoticz wiki.
How do I set maximum 500 millisecond to a Ping?
jannl
Post
by jannl » Friday 24 June 2016 11:24
Depends on your os. In windows it seems default ping timeout is 4secs. Please use google to find the ping settings for your os.
Flopp
Post
by Flopp » Saturday 25 June 2016 10:14
I am using RPi.
It works 99 out of 100 times but I want to stop the script if the ping fails which is only 1 out if 100.
What I don't still understand is why the script runs for 10 seconds and then return Ping fail.
It should return Ping fail and then exit script.
So it seems to be that the script runs 10 seconds then ping. Strange
jannl
Post
by jannl » Saturday 25 June 2016 10:40
If you do a ping from command line to a non-existing local ip-address, how long does it take?
You also do some file writes, not sure how long they take. Why not create a perl/python/badh script for this?
Flopp
Post
by Flopp » Saturday 25 June 2016 11:07
jannl wrote: If you do a ping from command line to a non-existing local ip-address, how long does it take?
It takes around 2 seconds.
Flopp
Post
by Flopp » Saturday 25 June 2016 11:08
I only write if the ping success otherwise it will/shall exit the script
Thank you for all help so far
Flopp
Post
by Flopp » Saturday 25 June 2016 11:10
jannl wrote: Why not create a perl/python/badh script for this?
I will test with a bash and see if that also gets error maybe the device that I ping is answering but takes to much time
jannl
Post
by jannl » Saturday 25 June 2016 11:11
Ok, did not read the script that carefully. How long does it take commandline before the ping fails?
Flopp
Post
by Flopp » Saturday 25 June 2016 11:13
jannl wrote: Ok, did not read the script that carefully. How long does it take commandline before the ping fails?
Don't understand the question.
Do you mean before it goes to ELSE if it fails? Then it is 1-2 seconds, same as the test I did manually
jannl
Post
by jannl » Saturday 25 June 2016 11:32
What I mean is if you type 'ping (ip address)' and the ping fails, how long does it take?
jvdz
Posts: 2487 Joined: Tuesday 30 December 2014 19:25
Domoticz version: 4.107
Post
by jvdz » Saturday 25 June 2016 12:04
I think this is more a generic issue with the build in event system. I remember having looked at this a while ago and know that some scripts that contain shelling another program and capturing its output, simply hangs for no reason when shelled by the Event system.
In general I always schedule these type of check scripts anyway via a cron job as it will else slow down the event system since it is single threaded.
Jos
jvdz on Saturday 25 June 2016 15:45, edited 2 times in total.
jannl
Post
by jannl » Saturday 25 June 2016 14:30
Yeah, same here
Flopp
Post
by Flopp » Monday 27 June 2016 0:07
Is this true?
Lua is not the best place to run scripts which are purely inserting a delay, as Domoticz can only run 1 Lua script at a time, so while the delaying script is running nothing else will.
viewtopic.php?p=18984#p18984
is Yes, will the second, third.... LUA script run after the first is ready?
Flopp
Post
by Flopp » Monday 27 June 2016 0:15
jannl wrote: What I mean is if you type 'ping (ip address)' and the ping fails, how long does it take?
Sorry for late answer but I didn't know how to timestamp PING now I know
This is my replay when fail
[1466979064.011055] From 192.168.x.x icmp_seq=1 Destination Host Unreachable
[1466979064.011917] From 192.168.x.x icmp_seq=2 Destination Host Unreachable
[1466979064.012433] From 192.168.x.x icmp_seq=3 Destination Host Unreachable
[1466979067.011018] From 192.168.x.x icmp_seq=4 Destination Host Unreachable
[1466979067.011728] From 192.168.x.x icmp_seq=5 Destination Host Unreachable
[1466979067.012290] From 192.168.x.x icmp_seq=6 Destination Host Unreachable
jannl
Post
by jannl » Monday 27 June 2016 10:14
No idea what I am seeing there.
Please use the same command you typed in your code.
Flopp
Post
by Flopp » Monday 27 June 2016 10:37
jannl wrote: No idea what I am seeing there.
It is seconds since 1970.
[1466979064.011055]
between pings it is 0.0009 seconds
[1466979064.011917]
0.0005 seconds
[1466979064.012433]
It seems that Ping do 3 attempts and then wait 3 seconds and do 3 again.
I think I will solve it by using Cron.
Thanks for your help
jannl
Post
by jannl » Monday 27 June 2016 11:14
What ip address exactly are you pinging?
Flopp
Post
by Flopp » Monday 27 June 2016 11:19
ADMIN please remove this post
Flopp on Monday 27 June 2016 11:20, edited 2 times in total.
