homebridge-edomoticz Plugin
bxlouis
- Domoticz version: 2020.1
Re: eDomoticz Homebridge-Plugin
Thank you Marci for your awesome work ! The blinds do work with Siri now.
I still have 2 questions, though :
- I set one of my blinds as "Inverted blind" in Domoticz, and I think it is not recognized as a blind by eDomoticz.
- It seems the 2 other blinds I use (set as "blind" in Domoticz) work inverted. They close when I say "open my blinds" and open when I say "close my blinds". It is strange since it works well with Domoticz. I tried to change that behavior through Elgato Eve or Insteon+ apps but there is no setting that allows to do that.
Thank you again for your help !
SeaTea
- Domoticz version: 3.5641
In my case this was not the solution, as npm seems to be installed, just not working without errors. (segmentation faults and illegal instruction)Marci wrote:Looks like the nodejs package from Raspbian Jessie repos now only installs the node binary. You'll have to then install npm separately:
sudo apt-get install npm
After (lots of) digging via google I found a solution which seems to work. At least I can install everything now.
I am using a Raspberry-PI model 1, which has a ARM-6 on board. It seems that the default installation of nodejs which was pre-installed on the domoticz SD-image was for ARM-7, which wil probably work on the RPI-2 and 3.
So I removed the pre-installed installed nodejs :
sudo apt-get remove nodejsCode: Select all
sudo rm -rf /usr/local/{lib/node{,/.npm,_modules},bin,share/man}/{npm*,node*,man1/node*} /var/db/receipts/org.nodejs.*
hash -r
wget https://nodejs.org/dist/latest-v6.x/node-v6.2.2-linux-armv6l.tar.gz
tar -xvf node-v6.2.2-linux-armv6l.tar.gz
cd node-v6.2.2-linux-armv6l
sudo cp -R * /usr/local/
cdCode: Select all
sudo npm install -g homebridge --unsafe-perm
sudo npm install -g forever
sudo npm install -g homebridge-edomoticz
I still have to configure and test the rest but at least installation worked now and logfile shows that it found some "platform accessory's" from my domoticz installation.
adjego
- Domoticz version: V3.5163
adjego wrote:Using this config i'm trying to get it to work. Something with authentication is going wrong. If i disable login all devices are fetched, if enabled with correct username and password set in config i get this:
Somebody has any pointers for me?
Did you by any change managed to have a look at this??Marci wrote:Will have a look at it this weekend...
SeaTea
I found the following in .forever log after restart/update of the plugin:
It seems that I have 2 places with node_modules. I don't know if this is something from the installation which did not succeed (see my previous message), but how can I check if the right homebridge-edomoticz module is used / updated ? Can I check actual (used) version somewhere ?
[6/22/2016, 3:27:31 PM] Warning: skipping plugin found at '/usr/local/lib/node_modules/homebridge-edomoticz' since we already loaded the same plugin from '/usr/lib/node_modules/homebridge-edomoticz'.
[6/22/2016, 3:27:35 PM] Loaded plugin: homebridge-edomoticz
- Marci
- Domoticz version: 3.8153
Inverted blinds have a different switchtypeval that hasn't been enabled yet.I still have 2 questions, though :
- I set one of my blinds as "Inverted blind" in Domoticz, and I think it is not recognized as a blind by...
These will need a manual override to invert them in the plugin. Leave them with me.- It seems the 2 other blinds I use (set as "blind" in Domoticz) work inverted. They close when I say "open my blinds" and open when I say "close my blinds". It is strange since it works well with Domoticz. I tried to change that behavior through Elgato Eve or Insteon+ apps but there is no setting that allows to do that.
Extended Domoticz homebridge-plugin for latest Homebridge - adds temp/humidity/pressure sensors, power consumption sensors, DarkSkies virtual weather station support, YouLess Meter support, general % usage support & switch/lamp status checking!
- Marci
Whichever node_modules folder you're running homeBridge itself from is the correct one. Delete the other.SeaTea wrote: It seems that I have 2 places with node_modules. I don't know if this is something from the installation which did not succeed (see my previous message), but how can I check if the right homebridge-edomoticz module is used / updated ? Can I check actual (used) version somewhere ?
- Marci
Nope - next on the list...adjego wrote:Did you by any change managed to have a look at this??
- Marci
Have a look for systemctl for running things at boot on jessie rather than the rc.d method of wheezy... odds on bet it's down to that.
Yesterday i've tried to run the homebridge + plugin on the stable domoticz image.
But i failed inside the installation process (Messed up with installing from pi users, which install commands run with sudo). Can someone tell me which steps are necessary to do for this running completely on domoticz 4384?
When i only want to have the sensors that are already inside domoticz throug homebridge, what do i have to configure inside the json? Only the roomid + Platform and no extra accessoires?
- Marci
Just follow steps in the first post...
I know. At the moment i'm trying to install everything on a clean raspbian jessie image. But also get errors from the npm section. Lots of "gyp ERR!"?Marci wrote:Just follow steps in the first post...
EDIT: Now i get:
pi@raspberrypi:~ $ sudo npm install -g homebridge
pi@raspberrypi:~ $
- Marci
Redo the npm lines with --unsafe-permPurejet wrote:I know. At the moment i'm trying to install everything on a clean raspbian jessie image. But also get errors from the npm section. Lots of "gyp ERR!"?Marci wrote:Just follow steps in the first post...
EDIT: Now i get:
pi@raspberrypi:~ $
BasPost
- Domoticz version: V2.2563
@Marci,
First off all, thanks for the excellent plugin! I've managed to install it with your excellent tutorial in the first post on my raspberry Pi, running Domoticz.
Everything works, except the .sh script which for starting at boot.
I've followed every step in your post: viewtopic.php?f=36&t=10272&p=72791#p72791
But when I start the script with:
I've got the following error in terminal:
I've attached the shell script which I created.
/etc/init.d/homebridge.sh startCode: Select all
pi@raspberrypi:~$ /etc/init.d/homebridge.sh start
/etc/init.d/homebridge.sh: line 30: unexpected EOF while looking for matching `"'
/etc/init.d/homebridge.sh: line 34: syntax error: unexpected end of file
pi@raspberrypi:~$
- homebridge.sh.zip
- (1.06 KiB) Downloaded 78 times
I did that. But every time i get more errors. I've also the error in the post above this. And another one;Marci wrote:Redo the npm lines with --unsafe-permPurejet wrote:I know. At the moment i'm trying to install everything on a clean raspbian jessie image. But also get errors from the npm section. Lots of "gyp ERR!"?Marci wrote:Just follow steps in the first post...
EDIT: Now i get:
pi@raspberrypi:~ $
Error: Cannot find module 'hap-nodejs'
at Function.Module._resolveFilename (module.js:326:15)
at Function.Module._load (module.js:277:25)
at Module.require (module.js:354:17)
at require (internal/module.js:12:17)
at Object.<anonymous> (/usr/local/lib/node_modules/homebridge/lib/cli.js:2:11)
at Module._compile (module.js:410:26)
at Object.Module._extensions..js (module.js:417:10)
at Module.load (module.js:344:32)
at Function.Module._load (module.js:301:12)
error: Forever detected script exited with code: 1
error: Script restart attempt #11
- Marci
Sounds like npm hasn't installed dependencies...Purejet wrote: I did that. But every time i get more errors. I've also the error in the post above this. And another one;
Head to /usr/local/lib/node_modules/... Then go into each sub folder you find there and run 'sudo npm install --unsafe-perm' for each module (homebridge, and homebridge-eDomoticz)
BasPost
Thank you so much @Justinb81, the script wants to start, but now with the following error:Justinb81 wrote:BasPost wrote:@Marci,
But when I start the script with:I've got the following error in terminal:Code: Select all
/etc/init.d/homebridge.sh startI've attached the shell script which I created.Code: Select all
pi@raspberrypi:~$ /etc/init.d/homebridge.sh start /etc/init.d/homebridge.sh: line 30: unexpected EOF while looking for matching `"' /etc/init.d/homebridge.sh: line 34: syntax error: unexpected end of file pi@raspberrypi:~$
Here is your corrected script the " was wrong
homebridge.sh.zip
pi@raspberrypi:/etc/init.d$ /etc/init.d/homebridge.sh start
Starting HomeBridge
Password:
bash: /usr/bin/forever: No such file or directoryEDIT:
Manual start with
forever start /usr/bin/homebridgeCode: Select all
pi@raspberrypi:~$ forever start /usr/bin/homebridge
warn: --minUptime not set. Defaulting to: 1000ms
warn: --spinSleepTime not set. Your script will exit if it does not stay up for at least 1000ms
info: Forever processing file: /usr/bin/homebridge
I think I've managed it!
I was reading the post of Justinb81: viewtopic.php?f=36&t=10272&start=340#p89413
And tried his sh script. And now no errors and everything seems to work. I did sudo reboot and it seems to start. I can control my lights with Siri.
I'm a beginner with Linux, so I would like to now what the difference is what I did
- Marci
Aye - the current Domoticz image differs to the one that was around when I wrote all that. I need to do a fresh build and update the instructions.
NewFolk
Do you know about https://github.com/dotsam/homebridge-milight ?Marci wrote:Am currently awaiting files from a contributor which add in RGB support... soon as they arrive I'll update the repos.
I`m using it 2 weeks and it is pretty stable.
BasPost
Ok, I tottaly screwed up my installation. I re-installed the domoticz-raspberrypi-sdcard-4834.7z image and restored my domoticz.db
Domoticz is running fine. But for now I don't installed the eDomoticz plugin.
So my RPi is a clean install on Rasbian Jessy, if I'm correct.
I also did apt-get update and apt-get upgrade
When I do in terminal "node -v" I get: "illegal instruction"
Also when I do: "homebridge" in terminal, as suggested in this topic: viewtopic.php?f=31&t=12460 I get: "illegal instruction"
So I don't wan't to continue, trying to install the eDomoticz plugin.
What to do?
What to do?
NewFolk
I used this tutorial on Jessie and Rpi3 https://github.com/nfarina/homebridge/w ... spberry-Pi
