issue with io.popen and curl on localhost
jmleglise
Domoticz version: 2022.1
Post by jmleglise »
I'm loosing my mind...
This lua script doesn't work and return a log error "running for more than 10 seconds":
local handle=assert(io.popen('curl.exe 127.0.0.1:8081'))
local response = handle:read('*all')
handle:close()
For debugging, I ve tried the following :
This shell command works fine (in a terminal) and complete in about 5 sec:
This same lua script works fine too :
local handle=assert(io.popen('curl.exe www.google.fr'))
handle:close()
I have deactivated my Website Protection in Domoticz settings.
What am I missing ?
My aim is to read the log history of a temp sensor and test if temp goes under 0°C in the past few hours . (http://127.0.0.1:8081/json.htm?type=gra ... &range=day)
My script : https://github.com/jmleglise
RFXTRX433E: Blind Somfy RTS, Portal Somfy Evolvia, chacon IO, Oregon, PIR sensor PT2262
My Last project : Location de vacances a Ouistreham vue mer
KMTronic USB relay
Chinese Z-WAVE: Neo CoolCam
jmleglise
Re: issue with io.popen and curl on localhost
Post by jmleglise »
It's crazy, I continue my investigation ...
This first script doesn't work. ("running for more than 10sec ...")
script_device_testjson.lua
commandArray={}
if (devicechanged['ManualLaunchScript'] == 'On' and otherdevices['ManualLaunchScript'] == 'On') then
	commandArray['ManualLaunchScript']='Off'
	handle:close()
	print(response)
When the same in a time script works !!! I have an output in log every minute.
script_time_testjson.lua
commandArray={}
handle:close()
print(response)
What's going on ?!?
KMTronic USB relay
ridderr
Post by ridderr »
I had the same issue today and found that when I switch my lights off/on from my mobile it all works fine. When I switch lights via the browser I'm also getting an 10 seconds error. Will do some more investigation and the i probably will raise and bug.
