Has anyone has success with Zoneminder and Domoticz?
resentedpoet
Post by resentedpoet »
Has anyone had any success with Zoneminder and Domoticz? I have Zoneminder set up and working fine on my server and can see the streams in my browser no problem from another PC. I wanted to then integrate it into Domoticz, but I can't for some reason get the streams to work. Not sure what I am doing wrong here, was hoping someone could point me in the right direction.
Thanks,
ThinkPad
Re: Has anyone has success with Zoneminder and Domoticz?
Post by ThinkPad »
As far as i know Domoticz only supports a JPEG/MJPEG stream. So have a look at the streams that Zoneminder spits out.
By the way, you don't happen to have Synology NAS? Otherwise you could add the cams there and use this script i made: http://domoticz.com/forum/viewtopic.php?f=23&t=6794
resentedpoet
Hi Thinkpad,
Ok, didn't know about the limitations, thanks for the info. I've been trying any and all the suggestions from http://www.ispyconnect.com/man.aspx?n=Zoneminder but still no luck.
Blipvert
Domoticz version: V3.5248
Post by Blipvert »
I use the following imageURL to get my Zoneminder cameras (3 mpeg and 1 rtsp) into Domoticz:
<zoneminder_folder>/cgi-bin/zms?mode=single&monitor=<monitor_number>&
So, for example, if your Zoneminder web page is accessed via http://192.168.1.23:8080/zm and you want to get your camera 1 (monitor 1 in Zoneminder) configured in Domoticz, the Domoticz config would be:
Name: <name you wish for the camera>
IP Address: 192.168.1.23
Port: 8080
Username: <the username you use to access Zoneminder; blank if none>
Password: <the password you use for the username above; blank if none>
imageURL: zm/cgi-bin/zms?mode=single&monitor=1&
The version of ZoneminderI use is 1.29, and my Domoticz is v.3.4834 on a Raspberry Pi.
hasan
Post by hasan »
Blipvert wrote:I use the following imageURL to get my Zoneminder cameras (3 mpeg and 1 rtsp) into Domoticz:
Port: 8080
Hi Blipvert,
I follow your instruction but DOMOTICZ doesn't show anything. Zoneminder shows picture from cameras well. Do you have any ideas why?
Blipvert
Post by Blipvert »
What is the exact URL that you use to access your Zoneminder? (mask the IP)
hasan
Post by hasan »
http://192.168.4.111/zm
Blipvert
Post by Blipvert »
Then your configuration should be:
Name: <name you wish for the camera on Domoticz>
IP Address: 192.168.4.111
Port: 80
Username:
Password:
That is, for as long as the camera that you want to access is the monitor 1 in Zoneminder; try increasing the number if you have more than one camera configured on Zoneminder.
For a test, you can try to access this url:
http://192.168.4.111/zm/cgi-bin/zms?mod ... &monitor=1
(again, change the monitor number to fit your needs)
If this does not show you an image, then there is something missing on your Zoneminder config.
hasan
Post by hasan »
Port: 80
Username:
Password:
This was exactly what I tried :( so I'll check ZM configuration ;)
Blipvert
Post by Blipvert »
http://192.168.4.111/cgi-bin/zms?mode=single&monitor=1
Do you see an image if you try this url?
hasan
Post by hasan »
I installed everything from scratch and it is working now. Thanks for help...
woody4165
Post by woody4165 »
Just discovered zoneminder and it's really nice
Is there any possibility to get notified in domoticz when a motion is detected?
Trigun
Domoticz version: 4.10717
Post by Trigun »
hi there,
i know this is an old threat but i am hoping someone can help me out here.
I have zoneminder configured and working well(v1.30.4).
I would like to enable the zoneminder stream into domoticz.
I've read the posts but can't seem to get it to work.
thanks in advance!
Grtz
Trigun
Post by Trigun »
got it working.
the username and password is still tough though but without it, it working fine.
thnx!
jannnfe
Post by jannnfe »
woody4165 wrote: Saturday 11 November 2017 19:54 Hi
Have a look at my modification of zmeventserver here: https://github.com/jannnfe/zmeventserverDomoticz
