New to Domoticz, but have run a Raspberry PI v2 for 2+ years linked with LightwaveRF and home-brew/adapted PHP, Python and Ruby scripts controlling various aspects.
I'm actively looking at switching to Domoticz, and have invested in a Raspberry Pi v3 and RFXCom433E.
So far, got it installed and talking to one lightwave device, and a Somfy Rollixo RTS, which is where this next question comes from.
The raspberry pi "knows" when the alarm is set, based upon a digital input on the PiFace board.
Is there an easy way to "interlock" a device, i.e. the following logic:
if (alarmSet()) {
disableGarageDoorButton();
else if (alarmUnset()) {
enableGarageDoorButton();
An alternative, would be to intercept the button click for "Open" and NOT take any action if the alarm is current set/armed. This will prevent any "accidental" triggering of the alarm by fumbling the door open button!
I'm guessing it might be possible via a Lua script, but I have no idea where to start and what's the *best* approach for this.
Thanks in advance.
Interlocking devices
mmcnamee
Re: Interlocking devices
I guess this might also be used for heating / lighting purposes. e.g. shutting down the boiler when a window/door sensor opens.
Any direction or assistance greatly appreciated
mmcnamee
Not sure it's the most optimal, but this appears to work...
Create an Actual switch for the device, e.g. "RealSwitch"
Create a Virtual Switch called "Switch"
Create a LUA event script for the device, programming the required logic into the script, and call RealSwitch = ON / OFF from the virtual switch's script.
I guess this is why there's a $hiddenDevices "room" in Domoticz - to hide the real ones out the way?!
RayAmsterdam
You could do this in blockly
