Kodi event
gvanrekum
Kodi event
Post by gvanrekum »
I've got the following issue: I want Domoticz to automaticly start a radio channel (after x seconds) when kodi has stop playing (video/ audio).
I've got the play part working (JSON RPC), but I can't get the automatic part to work. Kodi sends an "on" command to Domoticz when its stops playing, but it also sends this "on" command between 2 videos, so that's useless.
Anyone got an idea?
Thanks.
Greetz,
Gerard
gvanrekum
Re: Kodi event
Post by gvanrekum »
Anyone an idea?
Greetz,
Gerard
Dnpwwo
Re: Kodi event
Post by Dnpwwo »
You could use an event and check the if the Kodi was "on" and if the last updated time was greater than a certain number of seconds, if it was then turn the radio on.
The number of seconds might vary a little depending on the event type you use but you could easily turn it on in under a minute.
gvanrekum
Re: Kodi event
Post by gvanrekum »
Thanks, I will test this solution! :-)
