Stop Button on blinds
Hallo why is on the setup mask of the venetian blinds eu no stop action? That would make its easy to stop the blinds! There is only on and off action!
- gizmocuz
Re: Stop Button on blinds
Your talking about a blind, should be set to blind, and should have Open/Close (at least), and your talking about On/Off
Please post a screenshot of the widget
- Domoticz version: 3.8799
It is true that the stop button for venetian blinds does not do anything, but if you are opening the blinds and want to stop them at some point you just press the open button once more, and they will stop. Same goes for the close action. This works the same for both the blinds option and the venetian blinds (EU) option.
Now, from the apps its a different story. When using the Dromotica app by Sebastiaan Schimmel both the Blinds and the Venetian blinds option works correctly, but when using the Domoticz for Android app the Blinds options does not work at all.
For reference I'm using Nexa EJLR-1000 to control my screens (not blinds) but controller-module is for all motorised opening and closing.
Domoticz Beta 3.8799 on Windows10 with RFXtrx433 USB, firmware 94 and Aeotec Z-stick gen 5
My homematic is self made with esp12wifi modules. I control the blind with ip commands. Set pin.. To 1 or to 0.i have make my own pcb for control. When i but twis to on then set my pcb it twis to 1! I need also so a action like on action where i can write the ip command in it.
Best regards michael
hi
how did you add a stop button in between?
