piokuc
Re: Domoticz app 2.0
Post by piokuc »
Please always update all translation when build new version stable or beta because i done some changes in pl translation.
Wysłane z mojego SM-G920F przy użyciu Tapatalka
galadril
Domoticz version: latest
Post by galadril »
piokuc wrote:Please always update all translation when build new version stable or beta because i done some changes in pl translation.
I always do, please be patient..
Kringloper
Re: RE: Re: Domoticz app 2.0
Post by Kringloper »
galadril wrote:
karl8754 wrote:everything disappearing since the recent update (beta) on my stock Nexus 9.
This should be fixed in next release on beta!
Great, is working correctly. Tried some voice commands, which are working great with the upcoming wear-voice support it's becoming even more simple to quickly switch some stuff.
I was wondering if it's possible to use the voice commands in combination with a selector switch. I do have a selector switch for my sonos with two favourite radiostations. I can attach the selector switch to a voice command but don't know how to address the specific selector item.
Keep up the good work! Thanks for all the effort.
Verstuurd vanaf mijn Nexus 9 met Tapatalk
woody4165
Post by woody4165 »
Hi all
Don't understand if Selector Switch are managed by the app.
From the thread it seems yes, but I don't see it in the app.
I have this selector Switch
but in the app I see only the On and Off button.
Is it normal?
galadril
Post by galadril »
woody4165 wrote:but in the app I see only the On and Off button.
Is it normal?
No this should work. I also use selectors without any issues.
Can you please make a viewer account for me on you system to test?
galadril
Post by galadril »
piokuc wrote:Also good option will be add widget with shortcut to speech command to fast use from smartphone.
Jordyboytjuh wrote:A widget (which not causes battery drainage) with fast speech access would be awesome!!
There is a widget for QRCode scanning and Voice Commands in the next beta:
:lol:
woody4165
Post by woody4165 »
galadril wrote: No this should work. I also use selectors without any issues.
A viewer account on Domoticz, not the app, correct?
If yes, let me know and I will create a viewer for the specific switch and send you a PM with credentials
galadril
Post by galadril »
A viewer account on Domoticz, yes please
piokuc
Post by piokuc »
How i can add widget spech command to desktop ?
RoadXY
Domoticz version: 2.2331
Post by RoadXY »
piokuc wrote:How i can add widget spech command to desktop ?
First the beta needs to be released.
piokuc
Post by piokuc »
I have installed vesion 0.1.26* BETA
galadril
Post by galadril »
piokuc wrote:I have installed vesion 0.1.26* BETA
Thats on the dialog.. it's a placeholder id in the changelog dialog until the release is finished..
You can see the real beta number in the settings screen
jannl
Domoticz version: 2025.5.x
Post by jannl »
I have some issues/questions regarding the geofence function.
When configuring the option, load does not work (error message). The address is correct though.
Besides that I got a lot of entering/leaving area options. I now set the radius to 250m. I would think a smaller radius should work as well. What is a reasonable radius?
Any remarks on this these issues?
I use a motorola x force at the moment.
Jan Jansen
Domoticz version: Stable
Post by Jan Jansen »
I want to change Dromotica (no support selector) to Domoticz app. The Domoticz app looks nice. But for me there is an issue with the security panel (using the free Domoticz app).
When I leave my house (using Dromotica) I switch security status >> armed away. I close the app, turn off WiFi and lock the door. Using dromotica everything ok (security status has changed). Using Domoticz app (same way) security status did not change.
Am I doing something wrong or do I need more patience?
jannl
Post by jannl »
Hm, for now geofencing does not seem to work at all from de domoticz app
Only when I go into the settings the switch is being updated. Am I missing a setting somewhere?
galadril
Post by galadril »
jannl wrote:Besides that I got a lot of entering/leaving area options. I now set the radius to 250m. I would think a smaller radius should work as well. What is a reasonable radius?
I normally use around 400m
jannl wrote:Hm, for now geofencing does not seem to work at all from de domoticz app
Ill look into this
jannl
Post by jannl »
Ok, thx. I left home this morning but still the switch did not operate. I am about 30km away now.
Just let me know if you need any info
packstlaurent
Post by packstlaurent »
Is it possible to edit variable from application ?
Thanks,
galadril
Post by galadril »
packstlaurent wrote:Is it possible to edit variable from application?
No not yet
Varazir
Post by Varazir »
As I can't search for the word NFC, i'll ask.
I'm running lite and can't enable the NFC( I need premium ) but still my phone asks me if I like to use the app as NFC reader.
There are no way I can sett default NFC app as far as I know ( except only have one NFC app) so it weary irritating to have to choose every time.
Can you please remove the NFC part from light as it can't be used anyway.
TIA
Daniel
Raspberry PI 4 with RaZberry Controller 2016 ZWave+ and CC2531(zigbee)
Several IKEA devices/z-wave devices
