I use ubuntu 12.04, and domoticz version 2.3266
I am unable to open domoticz.db file using "SQLite Data browser" or the "sqliteman" that comes with ubuntu.
Any suggestions, please?
thanks.
how to view/edit "domoticz.db" file? Topic is solved
SweetPants
Re: how to view/edit "domoticz.db" file?
I'm using SQLIteman on Ubuntu 14.04 and can perfectly open the domoticz.db file.
You need to supply more information, do you get an error? Why use Ubuntu 12.04, that is an ancient version?
kman
Thank you SweetPants. Following your response, looked closely, it was permission issue. (reg. ubuntu 12.04, just compatibility issues with dev environment - will be moving to 14.04 very soon(in fact quite desperate!))
thanks again!
thanks again!
