Widom Universal Double Switch
marcoblacks
Post by marcoblacks »
Hi everybody!
I am trying to add the widom double switch to Domoticz running on Raspberry with Aeon z stick G5, only after a complete reset of the device Domoticz find and add the switch but i can't manage the configuration parameter of the widom...
Into the /config/widom dir there are only 2 xml files related just to single switch and another energy device...
At the moment my widom doesn't work properly:
If i change the status of one switch he take long time to apply changes;
If i switch on-off the light by button, the status is not updated into the software... and other...
Can someone help me??!!
Thanks a lot!
juankar
Domoticz version: 4.
Re: Widom Universal Double Switch
Post by juankar »
you say that
This happens with others double relays modules. Toyu must make a refresh for Reading real status. There is a fic that Works with Qubino and Philio
You have to add to the config file
       <CommandClass id="37">
                <TriggerRefreshValue Genre="user" Index="0" Instance="1">
                        <RefreshClassValue CommandClass="37" RequestFlags="0" Index="0" Instance="2" />
                        <RefreshClassValue CommandClass="37" RequestFlags="0" Index="0" Instance="3" />
                </TriggerRefreshValue>
        </CommandClass>
I explain in my post:
viewtopic.php?f=17&t=7043&start=60#p85037
Or you can try the script of egregius
viewtopic.php?f=17&t=7043&start=40#p51737
marcoblacks
Thanks 4 your answers! I'll try it...
I found also another widom config file for my device:
http://www.pepper1.net/zwavedb/device/8 ... -01-31.xml
I try to copy into my dir and also upgrade the other manufacturers.xml file with the new path and name of the config file..
But are there still the same problems...
I also noted that the xml sintax of the pepper1 database config file looks different from the other 2 widom config file (originally present in domoticz Config dir). Why? Are there different xml config format?
