Setup:
- Omniksol converter 3k TL2
- Domoticz installed on Synology NAS DS212j (DSM 6), v3.5110
- Also installed: Python, Git server, etc
Ok, so I got a nice Domoticz system here, loads of sensors and everything is working fine. Since 2 months I got my Solar PV system installed. It has a Omnik conveter. The converter is connected by Wifi to my network and sends its information directly to the Omnik Portal.
I found a script from Wouterrr to connect the converter to the Domoticz system. Although based on installing on a Pi, it should work on my setup (on Synology NAS).
https://www.domoticz.com/wiki/Omnik_Solar_Inverter
I followed all the steps;
- added all the virtual sensors in Domoticz
- created the shell script "omnik.sh", adjusted the root: /volume1/@appstore/domoticz/Omnik-Data-Logger/OmnikExport.py
- created dir on synology NAS called "scripts" in domoticz dir: "volume1/@appstore/domoticz/scripts/" folder.
- uploaded shell scripts with WinSCP
- made it executable with putty
- Next was creating dir "Omnik-Data-Logger" on NAS
- Did a clone of all the Git files and copied them to Synology
- Edited config.cfg (added ip + serial nr + host ip domoticz + port domoticz: 8084
- modified omnikexport.py
Output when testing with livestats.py, I got the following response. What am I doing wrong? Where will I be able to see feedback from the inverter?
admin@SynologyDS212j:/volume1/@appstore/domoticz/Omnik-Data-Logger$ python LiveStats.py
File "LiveStats.py", line 7, in <module>
import OmnikExport
File "/volume1/@appstore/domoticz/Omnik-Data-Logger/OmnikExport.py", line 25, in <module>
mysql_enabled = config.getboolean('mysql', 'mysql_enabled')
File "/usr/lib/python2.7/ConfigParser.py", line 368, in getboolean
v = self.get(section, option)
File "/usr/lib/python2.7/ConfigParser.py", line 340, in get
raise NoOptionError(option, section)
ConfigParser.NoOptionError: No option 'mysql_enabled' in section: 'mysql'
It looks like it has something to do with a sql database?
Help connecting Omnik PV converter to Domoticz
- thijsdebets
- Domoticz version: 3.4834
Re: Help connecting Omnik PV converter to Domoticz
You might need to disable MySQL in Config.cfg:
[mysql]
# Enable for exporting to a mysql database
mysql_enabled = false
# Host where the mysql server is active
mysql_host = 127.0.0.1
mysql_user =
mysql_pass =
mysql_db =
[pvout]
[mysql]
mysql_user =
mysql_pass =
mysql_db =
[pvout]
v3.4834 on RPiB2
P1 Smartmeter
Onmik Solarpanel
Evohome heating
NAS WOL/SOL
KiKa: 14 switches + 3 PIR
Extra
Full LAN detection w. arpscan
TravelTime via GoogleMaps in TempGraph
Internet speed in Othergraph
Control
20 Blockly and 5 LUA scripts
P1 Smartmeter
Onmik Solarpanel
Evohome heating
NAS WOL/SOL
Extra
Control
- Domoticz version: 2020.2
Did you ever get this to work?
I also have an Omnik inverter (don't know for sure, but think it is model 4K). Would love to connect it to Domoticz, but am running a Windows installation.
Is there a description available for this setup?
Hans
- galadril
- Domoticz version: latest
Have you checked my post?
http://www.domoticz.com/forum/viewtopic ... it=ginlong
the baseUrl for Omnik should be:
http://www.omnikportal.com:10000
Others are:
http://www.ginlongmonitoring.com:10000
http://log.trannergy.com:10000
http://www.solarmanpv.com:10000
for your Android:
Others are:
for your Android:
Yes, but I am trying to get this running on a Windows based domoticz server...galadril wrote:Have you checked my post?
Others are:
for your Android:
Hans
- galadril
Python scripts also run on windows.. right?
Just schedule it to run with Task Scheduler:
https://blogs.esri.com/esri/arcgis/2013 ... g-a-scrip/
