I have a owl power meter. It has just been reset and the logging from the last year is now on a dead "unit".
Is it somehow possible to merge the old and new units, or at least transfer the readings/log to the new unit somehow?
Merge units/readings
KoenVanduffel
Re: Merge units/readings
I have the same issue. When I excange the batteries of my weatherstation (Alecto WDS-19) the sensor pops up under a new idx number and starts logging all over. Is it possible to merge the data of the old idx with the new one.
I could make a script to plug the incoming data from the new idx into the old one. This is kind of messy however. A better way would be to be able to tell Domoticx idx xxx is actually the same as idx yyy.
- Shaggie_NB
viewtopic.php?f=12&t=9344&p=65003&hilit=transfer#p65003
Don't you guys have a search button on this forum?
PABben
Thanks!Shaggie_NB wrote:viewtopic.php?f=12&t=9344&p=65003&hilit=transfer#p65003
mistysnip
- Domoticz version: 2024.7
Reviving this old thread…
I'm having the same issue that was discussed but I don't seem to have the option to transfer data between devices like it's mentioned in the older post.
I could do it via SQL, but it's cumbersome.
Any ideas?
Any ideas?
