Gigaset Elements Cli - domoticz support
micbou
Re: Gigaset Elements Cli - domoticz support
Post by micbou »
I got everything up and working. I see my Base (red, because I need to set one of my sensors back up) and motion in the log from the motion detector. The motion switch doesn't change color on motion, right? Im planning to let the switch change to 'away' when the last person leaves the house (using the BT Beacon from this topic (index.php?mark_notification=29483&hash=6a92d7e0) and send me a Telegram message when a alert is triggered.
Any advice on how to get the 'mode' switch in there?
Again, thanks a lot. Really appreciate all the help and I learned a lot from all the steps you guided me through.
dynasticorpheus
Domoticz version: 2.3295
Post by dynasticorpheus »
Create a new selector switch:
Set it up like this:
The actions are:
script:///usr/local/bin/gigasetelements-cli -m home
script:///usr/local/bin/gigasetelements-cli -m custom
script:///usr/local/bin/gigasetelements-cli -m away
also in your /etc/gigasetelements-cli.conf change:
modus: home
into
modus:
Otherwise every time you run the cli it will change the modus into home
micbou wrote:I got everything up and working. I see my Base (red, because I need to set one of my sensors back up) and motion in the log from the motion detector. The motion switch doesn't change color on motion, right? Im planning to let the switch change to 'away' when the last person leaves the house (using the BT Beacon from this topic (index.php?mark_notification=29483&hash=6a92d7e0) and send me a Telegram message when a alert is triggered.
dynasticorpheus
I actually already have added telegram support in the cli itself but need to refine this a bit more before I push it to github.
micbou
Post by micbou »
Great!
How do I set an action w/ Blocky? I want to play a voice command and send a message via telegram.
dynasticorpheus
micbou wrote:Great!
Still need to work a bit more on the native Telegram support in my cli but Domoticz can also do this for you by calling a simple bash script in the on/off action field of a device:
Follow step 1, 2, 3, and 5 of below instructable to get an authorization token and chat ID. (step 4 not needed)
http://www.instructables.com/id/Telegra ... /?ALLSTEPS
Create telegram-cli.sh with below code and replace TOKEN / CHATID with those you got from doing above steps.
#!/bin/sh -e
# Telegram token
TOKEN=bot*************************************************
# Telegram chat ID
CHATID=12345678
curl -o /dev/null -s -X POST "https://api.telegram.org/$TOKEN/sendMessage" -F chat_id=$CHATID -F text="$1 $2 $3 $4 $5 $6 $7 $8 $9 $10"
Now you can call this script in the on/off action field in a device but first make sure it works by testing it in your terminal first. Use correct path of script but it should look like something below.
script:///home/user/script/telegram-cli.sh Hoi, dit is een TEST!
micbou
Post by micbou »
I got the Telegram service up, but I want to trigger it when the alarm goes of or even when motion is detected..
micbou
Post by micbou »
hi, I was forced to clean install my Domoticz/RPi3 today. I tried working through the installation again and it seemed to work, but I ran into this error running gigasetelements-cli -tt
root@raspberrypi:/etc# gigasetelements-cli -tt
Gigaset Elements - Command-line Interface v1.5.0b1
[-] Configuration     | LOADED   | /etc/gigasetelements-cli.conf
[-] Identity          | VERIFIED | User logged in successfully.
[-] Authentication    | SUCCESS  |
[-] Basestation       | ONLINE   | E52C011F30C1BE84C86895D96C76D693
[-] Status            | GREEN    | Modus HOME
[-] ERROR             | UNKNOWN  | HTTPConnectionPool(host='192.68.1.112', port=8080): Max retries exceeded with url: /json.htm?type=command&param=addlogmessage&message=Gigaset%20Elements%20-%20Command-line%20Interface:%20Domoticz%20mode%20started (Caused by NewConnectionError('<requests.packages.urllib3.connection.HTTPConnection object at 0x763cd290>: Failed to establish a new connection: [Errno 101] Network is unreachable',))
when I switch mode in the selector the log shows:
2016-05-29 22:46:53.652 (Gigaset Elements Modus) Light/Switch (Gigaset Elements Modus)
2016-05-29 22:46:54.445 Executing script: /usr/local/bin/gigasetelements-cli
2016-05-29 22:46:55.025 Error: Error executing script command (/usr/local/bin/gigasetelements-cli). returned: 512
Any idea?
dynasticorpheus
micbou wrote:hi, I was forced to clean install my Domoticz/RPi3 today. I tried working through the installation again and it seemed to work, but I ran into this error running gigasetelements-cli -tt
Any idea?
Best guess would be an authorization issue. In domoticz settings check the option Local Networks (no username/password) and add
127.0.0.*;192.68.1.*
btw are you sure your ip is 192.68.1.112 and not 192.168.1.112 ???
francocouly
Post by francocouly »
I have some problems with the gigasetelements-cli.
I have created 3 .sh scripts that refer to the 5 actions from the Gigaset Elements System :
2016-05-30 17_24_25-Photos.png (68.9 KiB) Viewed 4940 times
but impossible to have the Domoticz working. No errors, but no actions.
For example, the away.sh script contain :
#!/bin/bash
/etc/gigasetelements-cli/gigasetelements-cli.py -m away -q > /dev/null
However, my scripts runs well in putty, changing the mode of the Gigaset Elements System.
Can you help me please ? :)
For information, I run Domoticz and gigasetelements-cli on my Synology NAS.
micbou
Post by micbou »
:oops: embarrassing! Sorry for wasting your time on this one
micbou
Post by micbou »
@francocouly, does below work?
Schermafbeelding 2016-05-30 om 17.36.27.png (269.64 KiB) Viewed 4937 times
francocouly
No, it doesn't work, like the previous settings :
2016-05-30 17_47_17-Domoticz.png (72.02 KiB) Viewed 4934 times
and nothing in the logs :
2016-05-30 17_45_30-TripAdvisor.png (5.49 KiB) Viewed 4934 times
It's very weird, I don't understand :/
dynasticorpheus
francocouly wrote:No, it doesn't work, like the previous settings :
There is really no need to create separate scripts if you do a regular install. Please run below code:
pip install --upgrade https://github.com/dynasticorpheus/gigasetelements-cli/zipball/develop
and follow below instructions:
viewtopic.php?f=38&t=8404&start=40#p85496
EDIT:
Don't know if you can do a regular install on a NAS but if not than I would suggest you put "python" in front of your command:
#!/bin/bash
python /etc/gigasetelements-cli/gigasetelements-cli.py -m away -q > /dev/null
francocouly
Here is my configuration :
Screen Shot 2016-05-30 at 23.02.28.png (230.5 KiB) Viewed 4907 times
And my switch :
Screen Shot 2016-05-30 at 23.02.44.png (272.33 KiB) Viewed 4907 times
The sensors are OK, but still not able to set the modus with the script. It's running well in cmd line :
Screen Shot 2016-05-30 at 23.06.17.png (108.05 KiB) Viewed 4907 times
Thank you for your help
dynasticorpheus
francocouly wrote:Hi,
And my switch :
I replicated your setup and it was working so we need to have a closer look, let's first route the output to a text file. Please share the output.
script:///etc/gigasetelements-cli/gigasetelements-cli.py -m home >> /tmp/gigasetelements-cli.log
francocouly
thanks for your return !
when I add script:///etc/gigasetelements-cli/gigasetelements-cli.py -m home >> /tmp/gigasetelements-cli.log, no .log file can be found in my /tmp folder. Perhaps a problem of rights ?
dynasticorpheus
Can you try again using below .sh script? Perhaps you first need to "cd" into the correct directory due to environment constraints?
#!/bin/bash
cd /etc/gigasetelements-cli
python gigasetelements-cli.py -m away
francocouly
Still not working.
the log file is created but empty, even if I add a "sudo -u admin" before the python command in the .sh script, add all the rights to this file, and the same for the log file
dynasticorpheus
francocouly wrote:Still not working.
I needed to specify the full path to python to get it working. Can you try as well. First check if it is also /usr/bin/python for you.
#!/bin/bash
/usr/bin/python gigasetelements-cli.py -m away
francocouly
Yessss ! It works perfectly :)
Thank you very much for your support !
