Radiation monitor value from json to Domoticz, how to? Topic is solved
costo
Domoticz version: 2025.1
Post by costo »
Hi, I have a radiation-monitor that shows the local radiation in a browser, on 192.168.178.20 showing this:
uRADMonitor 12000059
type:1 hw:108 sw:111 SI29BGradiation:13CPM
average:9.29CPM
temperature:29.44C
voltage:377V (39%)
uptime:150350s
wdt:49s
ip:192.168.178.20
server:23.239.13.18
http:200
and also a json string on 192.168.178.20/j like this:
{"data":{ "id":"12000059","type":"1","detector":"SI29BG","cpm":9,"temperature":28.44,"uptime": 151444}}
I'd like to import at least the cpm value in Domoticz but I cannot figure out how to parse the json and/or import the data into Domoticz. I'm more a hardware guy , not a software guy.
I hope someone can help me a bit in showing how to import the measurements into Domoticz.
b.t.w. I'm running Domoticz on a RPi 2B+
Westcott
Re: Radiation monitor value from json to Domoticz, how to?
Post by Westcott »
Hi Costo,
Have a look at this topic, it shows how to use a Lua script to read, decode, and upload JSON data.
http://www.domoticz.com/forum/viewtopic.php?t=11450
costo
Post by costo »
Westcott wrote:Hi Costo,
Thank you for the response Westcott. It took some time before I jumped into the topic but it is so much more complicated than what I want that it does not make any sense to me.
I come up to this script:
commandArray={}
json = (loadfile "/home/pi/domoticz/scripts/lua/JSON.lua")()  -- For Linux
-- json = (loadfile "D:\\Domoticz\\scripts\\lua\\json.lua")()  -- For Windows
local cpm = " "
local uptime = " "
local jsondata    = assert(io.popen('curl http://192.168.178.20/j')
local jsondevices = jsondata:read('*all')
jsondata:close()
print(cpm)
print(uptime)
I named it "cpm_data.lua" and copied it in the lua script folder but now it makes even less sense to me. I made a virtual sensor of the type 'custom sensor' that got idx 425. I do not see the connection between the script and the device.
I just get a headache trying to understand this :?
Westcott
Post by Westcott »
Yes, it's not easy, is it!
First, if you run '192.168.178.20/j' in a browser, do you get data?
Second, do you have the loadfile JSON.lua in the folder?
Third, there's a certain naming convention for Lua scripts to be run by Domoticz from the lua folder.
Yours should be called 'script_time_cpm_data.lua' to run every minute.
Fourth, add a 'print("cpm_data") - or whatever text you fancy - somewhere in your script to show that it actually executing.
Then we can go on to decoding the JSON data, and updating devices.
costo
Post by costo »
O.K. I try to do the 4 steps:
A: yes I get this data when I run 'http://192.168.178.20/j' in a browser, the data looks like:
{"data":{ "id":"12000059","type":"1","detector":"SI29BG","cpm":6,"temperature":26.50,"uptime": 1124204}}
B: No I do not see JSON.lua in the JSON.lua in the ... home/pi/domoticz/scripts/lua folder on the RPi.
C: I renamed the script to \script_time_cpm_data.lua
D: I get this error message every minute:
Error: EventSystem: in /home/pi/domoticz/scripts/lua/script_time_cpm_data.lua: /home/pi/domoticz/scripts/lua/script_time_cpm_data.lua:3: attempt to call a nil value
edit: after searching I found at: https://www.domoticz.com/wiki/Lua_-_json.lua the file JSON.lua.
I copied it to the script/lua folder and now the error_messages are gone.
In the log file I see now the printed sentence : LUA: cpm_data every minute.
I guess I make some progress
costo
Post by costo »
Westcott wrote: Then we can go on to decoding the JSON data, and updating devices.
Hi Westcott,
Java script like language is very abstract that's why I cannot figure out how to decode the value.
The code I have prints the lines : <LUA: cpm> and the just <LUA:> without a value
commandArray={}
local cpm = " "
local uptime = " "
local jsondata    = assert(io.popen('curl http://192.168.178.20/j'))
jsondata:close()
local jsoncpm = json:decode(cpm)
print('cpm')
print (cpm)
Some help would be very much appreciated.
Westcott
Post by Westcott »
Have you installed JSON.lua yet?
costo
Post by costo »
Westcott wrote:Have you installed JSON.lua yet?
I copied the file JSON.lua into the scripts/lua folder. That seems to work because the the line print('cpm') prints LUA: cpm into the log.
JSON.lua is a large file , 35kb including all the comments, I got it from here: https://www.domoticz.com/wiki/Lua_-_json.lua
Westcott
Post by Westcott »
I think we are getting there.
In your script, after the line -
insert these 2 lines -
cpm=jsoncpm.cpm
uptime=jsoncpm.uptime
costo
Post by costo »
Westcott wrote:I think we are getting there.
cpm=jsoncpm.cpm
I inserted the 2 lines, it does not make any difference in what is printed into the logfile.
print (cpm) prints LUA:
my feeling say that cpm should hava become the value cpm from the string that was decoded
edit: Stupid me !! I copied the script into the wrong folder
experimenting now to see what happens.
Westcott
Post by Westcott »
Try -
print(jsondevices)
local jsoncpm = json:decode(jsondevices)
costo
Post by costo »
I get errormessage in this line: cpm=jsoncpm.cpm
2016-05-06 22:14:00.487 Error: EventSystem: in /home/pi/domoticz/scripts/lua/script_time_cpm_data.lua: /home/pi/domoticz/scripts/lua/script_time_cpm_data.lua:14: attempt to index local 'jsoncpm' (a nil value)
Westcott
Post by Westcott »
Did 'print(jsondevices)' print anything?
costo
Post by costo »
Yes < print(jsondevices) > did print the line that I used to see in the browser.
The line looks like:
2016-05-06 23:13:00.486 LUA: {"data":{ "id":"12000059","type":"1","detector":"SI29BG","cpm":11,"temperature":27.00,"uptime": 1224308}}
costo
Post by costo »
This is driving me nuts.
I have
commandArray={}
local cpm = " "
local uptime = " "
jsondata:close()
local jsonCPM = json:decode(jsondevices)
cpm = jsonCPM.cpm
uptime = jsonCPM.uptime
print(jsondevices) -- ok
print (jsonCPM)
print (cpm)
print (uptime)
4 print commands , only the line <print(jsondevices)> prints the json undecoded line.
The decoding is not taking place.
I have been trying many changes to see if it can print a decoded value but I get either no output or get a error message.
robpow
Domoticz version: Beta :)
Post by robpow »
I'm not home to test it right now myself but shouldn't the variables be read like this:
cpm = jsonCPM.data.cpm
Etc...
'Cpm' being under 'data'?
Matt
costo
Post by costo »
Thank you Matt.
I am very happy :D
uptime = jsonCPM.data.uptime
that is the solution for decoding the json string.
Next step is need to do is couple the data to the device IDX in Domoticz, so I can see my data on the dashboard.
I hope someone can help me with that.
