I have purchase the Raspberry PI GPIO EnOcean Kit (see url below) , but I can not find a tutorial to use it with Domoticz.
http://www.kubii.fr/cartes-extension-ca ... 03156.html
Can you please help me to find a tutorial to use it with Domoticz?
Thanks for your help
Raspberry GPIO EnOcean
davidfungf
Re: Raspberry GPIO EnOcean
You can redirect the serial traffic to Lan port by the following command.
EnOceanPi scored the / dev / ttyAMA0.
And then setup a LAN device in Domoticz configuration page by listening a localhost (port 7970) in the above example
root @ enoceanpi: ~ # apt-get install ser2net
root @ enoceanpi: ~ # echo "7970: raw: 0: / dev / ttyAMA0: 57600 8DATABITS NONE 1 stop bit"> /etc/ser2net.conf
root @ enoceanpi: ~ # / etc /init.d/ser2net restart
[ok] restarting Serial port to network proxy: ser2net.
root @ enoceanpi: ~ # cat /var/log/daemon.log
13:19:40 enoceanpi ser2net [2314]: ser2net startup-
SantyagoPL
I try configure FAM4PI (Hat for Raspberry Pi with UART communication) with Domoticz. I use ser2net setup from this topic and I see data on configured port. But how configure Domoticz to use these configuration? I not found any General Lan Device to setup FAM4PI via ser2net
Any hint or help?
