Notification if sensor is not online
Gabe
Post by Gabe »
Hi everybody,
I already check the Forum, but I couldnt find what I looking for me (maybe I overlooked).
I just try to find out if there already excisiting a script for follow
- Sent on time per day a command to all sensor to check if it is reachable or not
- if one sensor is not reachable sent a notification about push
Hope someone could help me.
commodore white
Re: Notification if sensor is not online
Post by commodore white »
You should check out dzvents. It has a short example script that runs every 5 minutes that does exactly what you're after.
You can keep your existing scripts as dzvents will run silently in the background. Convert your scripts if you need extra flexibility regarding triggers or you need to carry data over from one run of your script to the next.
Gabe
Post by Gabe »
ok thanks will check it
