LUA: create user variable from within LUA script?
blitzkneisser
Domoticz version: stable
Post by blitzkneisser »
Hi!
Is it possible to create a new user variable from within a LUA script, e.g. checking if a variable exists and if not, creating it?
jmleglise
Domoticz version: 2022.1
Re: LUA: create user variable from within LUA script?
Post by jmleglise »
Yes,
Check with this :
      if not uservariables['name'] then
          print('User Variable  doesnt exist.')
and create with the API; look here :
https://www.domoticz.com/wiki/Domoticz_ ... w_variable
My script : https://github.com/jmleglise
RFXTRX433E: Blind Somfy RTS, Portal Somfy Evolvia, chacon IO, Oregon, PIR sensor PT2262
My Last project : Location de maison de vacances a Ouistreham vue mer
KMTronic USB relay
Chinese Z-WAVE: Neo CoolCam
papoo
Domoticz version: 4.10
Post by papoo »
if(uservariables['variable_name'] == nil) then
commandArray['OpenURL']=url..'/json.htm?type=command&param=saveuservariable&vname='..url_encode('variable_name')..'&vtype=2&vvalue=1'
user variables wiki
papoo
Post by papoo »
to late for me
blitzkneisser
Ah, yes, of course!
jmleglise
Post by jmleglise »
Interesting. I didn't know url_encode. I found the code here : http://lua-users.org/wiki/StringRecipes if you need.
KMTronic USB relay
papoo
Post by papoo »
function url_encode(str)
  if (str) then
    str = string.gsub (str, "\n", "\r\n")
    str = string.gsub (str, "([^%w %-%_%.%~])",
        function (c) return string.format ("%%%02X", string.byte(c)) end)
    str = string.gsub (str, " ", "+")
  return str
