Nefit Easy™
Heursqem
Re: Nefit Easy™
Post by Heursqem »
pepijn wrote:
Heursqem wrote:so, got all working fine
Used the nefit-easy-http-server and within Domoticz condigured hardware as "Nefit Easy HTTP server over LAN interface"
Domoticz created 6 standard/default devices for me
How can I add devices using the listed endpoints below?
pepijn wrote:
https://github.com/robertklep/nefit-eas ... -endpoints
This is the list of supported endpoints.
which endpoints do you want to use?
already found a solution
think I can manage with lua scripting
Holland
Domoticz version: Beta Ch
Re: Nefit Easy™
Post by Holland »
@Henk
Have a look to this post ;viewtopic.php?f=17&t=9653&start=280#p76926
To add a little color to PM2 thingy. I had myself some issues to let it autostart. (used the work perfectly)
Only if you are using Jessie (check via hostnamectl) the following workaround solves the autostart issue;
1. Delete the pm2*.sh file in /etc/init.d
2. sudo pm2 startup systemd –u pi
3. pm2 start nefiteasyhttpserver.sh
4. pm2 save
Then reboot the machine to check if it works
* credits to this guy: http://tech.scargill.net/pm2-node-red-and-the-rock/
Henk
Re: Nefit Easy™
Post by Henk »
Hi Holland,
Many thanks for your reaction. Brings me no luck though. Tried these setting before you wrote this supply and tried it again but no auto startup from the nefit server after sudo reboot. All the steps finally give a positive feedback.
Took a look in the pm2 logs and there are some errors:
/home/pi/nefiteasyhttpserver.sh: line 1: $'\r': command not found
/home/pi/nefiteasyhttpserver.sh: line 3: $'\r': command not found
My script, when starting manual is working fine:
#!/bin/bash
/usr/local/bin/easy-server --serial=******** --access-key=******** --password=******** > /dev/null
So any idea what is going wrong? Can break lines in the script mess things up?
Holland wrote:@Henk
4. pm2 save
Holland
Re: Nefit Easy™
Post by Holland »
Indeed, I would think that nefiteasyhttpserver.sh is created in a windows tekst editor.
Recreate the file with nano, and copy past the 2 lines:
sudo nano nefiteasyhttpserver.sh
Henk
Re: Nefit Easy™
Post by Henk »
Could not imagine me creating the file in Windows, but to be sure I recreated the file. Same problems though. Any ideas?
Holland wrote:Indeed, I would think that nefiteasyhttpserver.sh is created in a windows tekst editor.
Holland
Re: Nefit Easy™
Post by Holland »
After you do:
and issue
pm2 list
what do you see?
See below what my pm2 returns what I issue pm2 list
│ App name │ id │ mode │ pid │ status │ restart │ uptime │ memory │ watching │
│ server │ 0 │ fork │ 610 │ online │ 0 │ 36h │ 32.324 MB │ disabled │
│ nefiteasyhttpserver │ 1 │ fork │ 617 │ online │ 0 │ 36h │ 2.309 MB │ disabled │
Henk
Re: Nefit Easy™
Post by Henk »
Yeah Holland,
that's the same over here for what I can see. The only thing that is different is the server line. Are you running something else that is important for my situation?
│ nefiteasyhttpserver │ 0 │ fork │ 624 │ online │ 0 │ 15h │ 2.578 MB │ disabled │
Holland
Re: Nefit Easy™
Post by Holland »
The server app is for my Sonos implementation
Henk
Re: Nefit Easy™
Post by Henk »
Hm,
cleared the logs for nefit easy server as shown above. This because there is no date and time stamp there with them.
Then did a sudo reboot and found in the pm2 log that the starting of the nefit server is not executed at all, and a new error log is not created. So nothing is going wrong I think. For the program it is, from my point of view it's not working as it should do.
Last part of the PM2.log:
2016-03-27 13:25:06: pm2 has been killed by signal, dumping process list before exit...
2016-03-27 13:25:06: Stopping app:nefiteasyhttpserver id:0
2016-03-27 13:25:06: App [nefiteasyhttpserver] with id [0] and pid [624], exited with code [0] via signal [SIGTERM]
2016-03-27 13:25:06: [PM2] Exited peacefully
My dump.pm2 is looking like this:
[{"name":"nefiteasyhttpserver","vizion":true,"pmx":true,"automation":true,"autorestart":true,"treekill":true,"exec_mode":"fork_mode","node_args":[],"pm_exec_path":"/home/pi/nefiteasyhttpserver.sh","env":{"_":"/usr/local/bin/pm2","SSH_CONNECTION":"192.168.178.18 60194 192.168.178.43 22","LOGNAME":"pi","HOME":"/home/pi","SHLVL":"1","LANG":"en_GB.UTF-8","PWD":"/home/pi","PATH":"/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games","MAIL":"/var/mail/pi","LS_COLORS":"rs=0:di=01;34:ln=01;36:mh=00:pi=40;33:so=01;35:do=01;35:bd=40;33;01:cd=40;33;01:or=40;31;01:su=37;41:sg=30;43:ca=30;41:tw=30;42:ow=34;42:st=37;44:ex=01;32:*.tar=01;31:*.tgz=01;31:*.arc=01;31:*.arj=01;31:*.taz=01;31:*.lha=01;31:*.lz4=01;31:*.lzh=01;31:*.lzma=01;31:*.tlz=01;31:*.txz=01;31:*.tzo=01;31:*.t7z=01;31:*.zip=01;31:*.z=01;31:*.Z=01;31:*.dz=01;31:*.gz=01;31:*.lrz=01;31:*.lz=01;31:*.lzo=01;31:*.xz=01;31:*.bz2=01;31:*.bz=01;31:*.tbz=01;31:*.tbz2=01;31:*.tz=01;31:*.deb=01;31:*.rpm=01;31:*.jar=01;31:*.war=01;31:*.ear=01;31:*.sar=01;31:*.rar=01;31:*.alz=01;31:*.ace=01;31:*.zoo=01;31:*.cpio=01;31:*.7z=01;31:*.rz=01;31:*.cab=01;31:*.jpg=01;35:*.jpeg=01;35:*.gif=01;35:*.bmp=01;35:*.pbm=01;35:*.pgm=01;35:*.ppm=01;35:*.tga=01;35:*.xbm=01;35:*.xpm=01;35:*.tif=01;35:*.tiff=01;35:*.png=01;35:*.svg=01;35:*.svgz=01;35:*.mng=01;35:*.pcx=01;35:*.mov=01;35:*.mpg=01;35:*.mpeg=01;35:*.m2v=01;35:*.mkv=01;35:*.webm=01;35:*.ogm=01;35:*.mp4=01;35:*.m4v=01;35:*.mp4v=01;35:*.vob=01;35:*.qt=01;35:*.nuv=01;35:*.wmv=01;35:*.asf=01;35:*.rm=01;35:*.rmvb=01;35:*.flc=01;35:*.avi=01;35:*.fli=01;35:*.flv=01;35:*.gl=01;35:*.dl=01;35:*.xcf=01;35:*.xwd=01;35:*.yuv=01;35:*.cgm=01;35:*.emf=01;35:*.axv=01;35:*.anx=01;35:*.ogv=01;35:*.ogx=01;35:*.aac=00;36:*.au=00;36:*.flac=00;36:*.m4a=00;36:*.mid=00;36:*.midi=00;36:*.mka=00;36:*.mp3=00;36:*.mpc=00;36:*.ogg=00;36:*.ra=00;36:*.wav=00;36:*.axa=00;36:*.oga=00;36:*.spx=00;36:*.xspf=00;36:","USER":"pi","SSH_TTY":"/dev/pts/0","SSH_CLIENT":"192.168.178.18 60194 22","SHELL":"/bin/bash","TERM":"xterm","pm_cwd":"/home/pi","nefiteasyhttpserver":{}},"pm_cwd":"/home/pi","exec_interpreter":"bash","pm_out_log_path":"/home/pi/.pm2/logs/nefiteasyhttpserver-out-0.log","pm_err_log_path":"/home/pi/.pm2/logs/nefiteasyhttpserver-error-0.log","pm_pid_path":"/home/pi/.pm2/pids/nefiteasyhttpserver-0.pid","NODE_APP_INSTANCE":0,"vizion_running":false,"TERM":"xterm","SHELL":"/bin/bash","SSH_CLIENT":"192.168.178.18 60194 22","SSH_TTY":"/dev/pts/0","USER":"pi","LS_COLORS":"rs=0:di=01;34:ln=01;36:mh=00:pi=40;33:so=01;35:do=01;35:bd=40;33;01:cd=40;33;01:or=40;31;01:su=37;41:sg=30;43:ca=30;41:tw=30;42:ow=34;42:st=37;44:ex=01;32:*.tar=01;31:*.tgz=01;31:*.arc=01;31:*.arj=01;31:*.taz=01;31:*.lha=01;31:*.lz4=01;31:*.lzh=01;31:*.lzma=01;31:*.tlz=01;31:*.txz=01;31:*.tzo=01;31:*.t7z=01;31:*.zip=01;31:*.z=01;31:*.Z=01;31:*.dz=01;31:*.gz=01;31:*.lrz=01;31:*.lz=01;31:*.lzo=01;31:*.xz=01;31:*.bz2=01;31:*.bz=01;31:*.tbz=01;31:*.tbz2=01;31:*.tz=01;31:*.deb=01;31:*.rpm=01;31:*.jar=01;31:*.war=01;31:*.ear=01;31:*.sar=01;31:*.rar=01;31:*.alz=01;31:*.ace=01;31:*.zoo=01;31:*.cpio=01;31:*.7z=01;31:*.rz=01;31:*.cab=01;31:*.jpg=01;35:*.jpeg=01;35:*.gif=01;35:*.bmp=01;35:*.pbm=01;35:*.pgm=01;35:*.ppm=01;35:*.tga=01;35:*.xbm=01;35:*.xpm=01;35:*.tif=01;35:*.tiff=01;35:*.png=01;35:*.svg=01;35:*.svgz=01;35:*.mng=01;35:*.pcx=01;35:*.mov=01;35:*.mpg=01;35:*.mpeg=01;35:*.m2v=01;35:*.mkv=01;35:*.webm=01;35:*.ogm=01;35:*.mp4=01;35:*.m4v=01;35:*.mp4v=01;35:*.vob=01;35:*.qt=01;35:*.nuv=01;35:*.wmv=01;35:*.asf=01;35:*.rm=01;35:*.rmvb=01;35:*.flc=01;35:*.avi=01;35:*.fli=01;35:*.flv=01;35:*.gl=01;35:*.dl=01;35:*.xcf=01;35:*.xwd=01;35:*.yuv=01;35:*.cgm=01;35:*.emf=01;35:*.axv=01;35:*.anx=01;35:*.ogv=01;35:*.ogx=01;35:*.aac=00;36:*.au=00;36:*.flac=00;36:*.m4a=00;36:*.mid=00;36:*.midi=00;36:*.mka=00;36:*.mp3=00;36:*.mpc=00;36:*.ogg=00;36:*.ra=00;36:*.wav=00;36:*.axa=00;36:*.oga=00;36:*.spx=00;36:*.xspf=00;36:","MAIL":"/var/mail/pi","PATH":"/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games","PWD":"/home/pi","LANG":"en_GB.UTF-8","SHLVL":"1","HOME":"/home/pi","LOGNAME":"pi","SSH_CONNECTION":"192.168.178.18 60194 192.168.178.43 22","_":"/usr/local/bin/pm2","status":"online","pm_uptime":1459006247355,"axm_actions":[],"axm_monitor":{},"axm_options":{},"axm_dynamic":{},"created_at":1459006247356,"restart_time":0,"unstable_restarts":0,"started_inside":false,"command":{"locked":false,"metadata":{},"started_at":null,"finished_at":null,"error":null},"versioning":null}]
Any ideas?
knights
Re: Nefit Easy™
Post by knights »
@pepijn or anyone else: is the return temperature also available from the Nefit? I checked the list of endpoints but I could not find anything similar. Can you confirm that this is not possible? Or perhaps the delta T of the water ?
Douwe
Re: Nefit Easy™
Post by Douwe »
I'm using Domoticz 3.5033 on the Pi. nefiteasyserver is running (PM2). Get the following log:
2016-04-02 10:14:30.852 Error: nefit thermostaat hardware (7) thread seems to have ended unexpectedly
2016-04-02 10:14:33.575 (Youless) YouLess Meter (Youless)
2016-04-02 10:14:43.590 (Youless) YouLess Meter (Youless)
2016-04-02 10:14:44.706 Hardware Monitor: Fetching data (System sensors)
2016-04-02 10:14:53.603 (Youless) YouLess Meter (Youless)
2016-04-02 10:15:01.171 Error: nefit thermostaat hardware (7) thread seems to have ended unexpectedly
2016-04-02 10:15:03.616 (Youless) YouLess Meter (Youless)
reboot domoticz and or Pi doesn't help anymore. (yes sudo apt-get update/upgrade)
any suggestion?
Marcel
Nefit Easy™
Post by Marcel »
My easy is woking but receive continous errors, anyone have a clue?
Verzonden vanaf mijn iPhone met TapatalkImage
SweetPants
Re: Nefit Easy™
Post by SweetPants »
Occasionally I also see the "Error: NefitEasy: Invalid data received (main)!" error, but not as often as you do.
I think this is due to communication problems with the backend.
Henk
Re: Nefit Easy™
Post by Henk »
Fixed my startup problem after reboot!
I had to modify the /etc/init.d/pm2-init.sh file
export PM2_HOME="/root/.pm2" altered to: export PM2_HOME="/home/pi/.pm2"
Henk wrote:Hm,
Any ideas?
knights
Re: Nefit Easy™
Post by knights »
Is there anyone who has some time and expertise and can look into the gas usage? Or can anybody show me in the direction to make this happen?
I did some research and you need to get the records from /ecus/rrc/recordings/gasusagePointer , which you translate to pagenumbers with help of <page>=ceil(<records>/32. Then you can use the /ecus/rrc/recordings/gasusage?page=<page> to get the daily usage. HW is water and CH is central heating.
pepijn
Re: Nefit Easy™
Post by pepijn »
This is the way to read the usage. The 'issue' is that it only shows yesterday's usage not the current usage. But if you don't mind to shift a day you could use the json api to publish the data into domoticz
knights
Re: Nefit Easy™
Post by knights »
You mean that it only shows the total usage untill yesterday ?
I would not mind having the usage being a day wrong. Is there anything you can do from your end to make this happen? :)
mvveelen
Re: Nefit Easy™
Post by mvveelen »
The easy-server on my Synology has been running fine for week, for months actually. Last week it suddenly crashed and when I restarted the Synology, everything was fine again.
Now I'm wondering: are there updates released once in a while for this easy-server? Or is it still the first one that was released and is it not likely to be updated?
RPi3b+/RFXCOM rfxtrx433E/Shelly/Xiaomi Gateway/Philips HUE Lights/Atag Zone One/2 SunnyBoy inverters/AirconWithMe/P1 smartmeter/Domoticz latest Beta
mvveelen
Re: Nefit Easy™
Post by mvveelen »
After updating to the latest DSM5.2 on my Synology, the easy-server stopped working. When I restart the Synology, it won't start.
When I start it from the command line, it works. Until I close my Mac.
I made a new script which should start the server when the Synology starts, but it doesn't work anymore.
Someone who knows what to do?
edit: solved. Just had to find my own posts in this topic to solve it :oops:
knights
Re: Nefit Easy™
Post by knights »
On a Dutch forum I found someone who got their gas usage working in Domoticz. The thing only is that he is using the Synology method to get his readings.
He shared me his source and gave me permission to share it with you. Below the link to the file, especially the push2domoticz.php is interesting.
Can someone look into his source and check if there is a way to use his coding for the nefiteasyhttpserver and domoticz?
https://martenhammann.stackstorage.com/ ... YDmH6YqS7K
