Sensor turned red, Possible to set different "timeouts" for sensors
burton666
Post by burton666 »
I have a soilmoisture sensor that reports soil-moisture every 30:min and reports battery-level if battery-level has changed since last reading. So the battery-level does not report changed level very often and Domoticz sets it to red color as it has lost comunication with sen sensor. Is it possible to set different timeouts for for sensors to turn red? Battery level for this sensor will only report ~ once every 24h.
gizmocuz
Re: Sensor turned red, Possible to set different "timeouts" for sensors
Post by gizmocuz »
If you set the sensor timeout to 90 minutes (or above 61), then your problem should be solved, if it send data every 30 minutes
