ELV Max! Heating control system
Rostikator
Re: ELV Max! Heating control system
Post by Rostikator »
thanks
Rpi+Domoticz+EQ3+RFLink
Rostikator
How to add Max! wall sensors or radiator sensors to floor plan ?
I see sensors in devices and sensors are added as used.
devices list.png (111.98 KiB) Viewed 3695 times
but in room plan edit I see only devices from rflink.
room edit.png (59.19 KiB) Viewed 3695 times
Thanks for help
R
blackdog65
Post by blackdog65 »
Hiya, :D
The ELV Max! isn't (yet) seen directly by domoticz. You need to create a dummy device in hardware, mine is called "EQ3" and note its idx (left column) then in the .maxbuddy/scripts folder, edit the .js file to your ip/port and the dummy idx/HID.
See here viewtopic.php?f=34&t=841&start=20#p15912 for some better advice/tips.
Then your ELV Max! devices should start to show in devices. A word of advice, add them one at a time so that you know which is which.
Sean
CubieTruck Master
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
Westcott
Post by Westcott »
I'm starting to be able to read directly from the Cube using Lua and a tcp socket.
So far I can get the Cube's raw response - next to decode it in Lua.
Then to try sending an 's' command.
Huge thanks to whoever wrote the PiHeating Python code, it really got me started.
blackdog65
Wow Westcott!
Great to hear. This section has been so lifeless recently that I almost ( almost ) decided to look into Evo Home :oops:
I look forward to seeing how you get on and trying it :D
Sean
CubieTruck Master
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
mvzut
Post by mvzut »
Westcott wrote:Hi all,
Any news on this Westcott? I would love to have direct support for the Cube in Domoticz. Most other main home automation packages have it, and I really think it could boost interest in both Domoticz and the ELV Max! System.
Once you have something beta ready, I would be more than happy to help you test it.
P.S. I think I saw the code for the ELV Max! Cube binding for OpenHAB somewhere, they already worked out all the decoding. Maybe this can help? If I was a programmer myself, and if I had more time, I would have loved to help myself...
EDIT: it's at https://github.com/openhab/openhab/tree ... ng.maxcube
Westcott
Post by Westcott »
Hi Mvzut,
Thanks for your interest!
My Cube broke, it wouldn't power up any more.
I've returned it to Conrad, but no response yet.
Thanks for the OpenHab mention, yes I've found a couple of similar descriptions.
My decoding of a single valve is almost complete.
Once I get a working Cube again, I can move to sending commands.
blackdog65
Hiya,
I think you'll find more than 1 waiting with interest :D
I'm holding my breath! :mrgreen:
CubieTruck Master
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
Westcott
Post by Westcott »
Hi all of you holding your breaths,
If I post some code here, could you try it for me, please?
Unfortunately there is quite a bit of setup first, to get the necessary Lua libraries installed.
mvzut
Post by mvzut »
Westcott wrote:Hi all of you holding your breaths,
Yes no problem, glad to contribute! Assuming you will give some explanation on the installation of the libraries.
Westcott
Post by Westcott »
OK, here we go.
I think this is how I did it...
First you need to update Lua to 5.2.
Then get the 'lua-socket' library, and the 'luarocks' installer/manager app.
Finally some 'luarocks' need to be installed.
The last step is a list of the installed 'rocks'.
Each step has to be successful before the next can run, I had a +lot+ of Googling to do here, and might have forgotten some bits.
sudo apt-get install lua5.2
sudo apt-get install lua-socket
sudo apt-get install luarocks
sudo luarocks install luasec
sudo luarocks install luasocket
sudo luarocks install basexx
luarocks list
Installed rocks:
basexx
   0.3.0-1 (installed) - /usr/local/lib/luarocks/rocks
luasec
   0.6-1 (installed) - /usr/local/lib/luarocks/rocks
luasocket
   3.0rc1-2 (installed) - /usr/local/lib/luarocks/rocks
mvzut
Post by mvzut »
I got stuck at the installation of the luasec rock, it complained about openssl.a or openssl.so or openssl.so.* not found. Openssl is installed on my system, but the files appeared to be in a non-standard location. Here's what I did to solve this:
sudo mkdir /usr/local/ssl
sudo cp /usr/lib/arm-linux-gnueabihf/libssl.* /usr/local/ssl
sudo luarocks install luasec OPENSSL_LIBDIR=/usr/local/ssl
Let us know when you have a script to test! ;-)
Westcott
Post by Westcott »
Nice one!
This might also work, before luasec -
sudo apt-get install libssl-dev
mvzut
Post by mvzut »
Westcott wrote:Nice one!
Tried that first, said it was already installed?!
Westcott
Post by Westcott »
Another possible way, watch out for the reverse quotes -
sudo luarocks install luasec OPENSSL_LIBDIR=/usr/lib/`gcc -print-multiarch`
mvzut
Post by mvzut »
Westcott wrote:Another possible way, watch out for the reverse quotes -
OK, but my solution was also ok, right? At least I have eveything installed now.
blackdog65
Hi again,
Just installed the lua libraries (same install problem) all good to go ;)
CubieTruck Master
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
jorishp
Post by jorishp »
Everything is installed. Can't wait to start testing.
Westcott
Post by Westcott »
Gosh, that makes - um - 3 of you!
Here is some Lua code, save it to a file somewhere, and run it interactively: 'lua yourfilename'
Then please copy the result back to here, together with a brief description of your Max devices.
You'll need to put your Cube's IP name/addr in the code.
Hopefully it will read the 'L response' ("Device List") from your cube.
local socket = require "socket"
local basexx = require "basexx"
--MaxIP='172.16.176.26'
MaxIP='KEQ0817132'
MaxPort=62910
function maxCmd_H(data)
--	print('H='..data)
function maxCmd_M(data)
--	print('M='..data)
function maxCmd_C(data)
--	print('C='..data)
function maxCmd_L(data)
print('L='..data)
	dec = basexx.from_base64(data)
	hex = basexx.to_hex(dec)
--	print("Hex="..hex)
	s = hex:sub(1,2)
	data_len  = tonumber(s,16) + 1
	valve_adr = hex:sub(3,8)
	valve_info = hex:sub(13,14)
	batt = bit32.extract(valve_info,7,1)
	bst  = bit32.extract(valve_info,3,1)
	mode = bit32.extract(valve_info,1,2)
print("Len="..data_len, "Adr="..valve_adr, "batt="..batt, "bst="..bst, "mode="..mode)
    if (data_len == 13) then	-- WallMountedThermostat (dev_type 3)
print("Wall thermostat")
	elseif (data_len == 12) then -- HeatingThermostat (dev_type 1 or 2)
		s = hex:sub(15,16)
		valve_pos = tonumber(s,16)
		s = hex:sub(17,18)
		setpoint = tonumber(s,16) / 2
		s = hex:sub(21,22)
		temp = tonumber(s,16) / 10
print("Valve pos="..valve_pos, "Setpoint="..setpoint, "Temp="..temp)
local tcp = socket.connect(MaxIP, MaxPort)
if not tcp then
	print("Socket connect failed for "..MaxIP..':'..MaxPort)
	return
tcp:settimeout(2)
while true do
    s, status, partial = tcp:receive()
    if (status) then
		print("TCP receive - "..status)
		break
    local line = (s or partial)
	local cmd  = line:sub(1,1)
	local data = line:sub(3)
	if (cmd == 'H') then
		maxCmd_H(data)
	elseif (cmd == 'M') then
		maxCmd_M(data)
	elseif (cmd == 'C') then
		maxCmd_C(data)
	elseif (cmd == 'L') then
		maxCmd_L(data)
		break
tcp:close()
jorishp
Post by jorishp »
tried it but this is my output
pi@raspberrypi ~ $ lua max.lua
lua: max.lua:1: module 'socket' not found:
	no field package.preload['socket']
	no file '/usr/local/share/lua/5.2/socket.lua'
	no file '/usr/local/share/lua/5.2/socket/init.lua'
	no file '/usr/local/lib/lua/5.2/socket.lua'
	no file '/usr/local/lib/lua/5.2/socket/init.lua'
	no file './socket.lua'
	no file '/usr/share/lua/5.2/socket.lua'
	no file '/usr/share/lua/5.2/socket/init.lua'
	no file '/usr/local/lib/lua/5.2/socket.so'
	no file '/usr/lib/arm-linux-gnueabihf/lua/5.2/socket.so'
	no file '/usr/lib/lua/5.2/socket.so'
	no file '/usr/local/lib/lua/5.2/loadall.so'
	no file './socket.so'
stack traceback:
	[C]: in function 'require'
	max.lua:1: in main chunk
	[C]: in ?
Lua 5.2.1  Copyright (C) 1994-2012 Lua.org, PUC-Rio
> ^C
pi@raspberrypi ~ $ luarocks list
Installed rocks:
basexx
luasec
luasocket
