Somfy telis 4 RTS
renebiemans
Somfy telis 4 RTS
I'd like to connect my somfy remote and somfy screen to domoticz. When I look in the logging of domoticz I see the following error:
Error: RFLink: Unhandled switch type: RTS
If I connect RFLink to my laptop I see the following commands:
all(1,2,3 and 4)
20;0E;RTS;ID=554637;SWITCH=01;CMD=UP;
20;0F;RTS;ID=554637;SWITCH=01;CMD=MY;
20;10;RTS;ID=554637;SWITCH=01;CMD=DOWN;
1
20;11;RTS;ID=514637;SWITCH=01;CMD=UP;
20;12;RTS;ID=514637;SWITCH=01;CMD=MY;
20;13;RTS;ID=514637;SWITCH=01;CMD=DOWN;
2
20;14;RTS;ID=524637;SWITCH=01;CMD=UP;
20;15;RTS;ID=524637;SWITCH=01;CMD=MY;
20;16;RTS;ID=524637;SWITCH=01;CMD=DOWN;
3
20;17;RTS;ID=534637;SWITCH=01;CMD=UP;
20;18;RTS;ID=534637;SWITCH=01;CMD=MY;
20;19;RTS;ID=534637;SWITCH=01;CMD=DOWN;
4
20;1A;RTS;ID=544637;SWITCH=01;CMD=UP;
20;1B;RTS;ID=544637;SWITCH=01;CMD=MY;
20;1C;RTS;ID=544637;SWITCH=01;CMD=DOWN;
It looks like RFLink can get the data and also translates it but Domtoicz can;t use it because the device RTS is unknow. Is this correct? Is it possible to get it in domoticz?
Best regards,
Rene
all(1,2,3 and 4)
1
2
3
4
Best regards,
Rene
renebiemans
Re: Somfy telis 4 RTS
I have a reaction from Frank of RFLink.
He explains that the code for receiving SOMFY is implemented in domoticz yesterday and that it will be soon available.
The sending part needs some attention in RFLink, when he has some time he will implemented that also.
deennoo
Which is your réception range ?
Got a Aurel rtx mid 5v ans have to be very close from rflink to recieve remote order 1 mètre maxi.
http://domo-attitude.fr
Willem81
Hi all! Can anyone confirm that Somfy Telis1 remote works with RFLink? Then I will buy one. My centralis does not work with RFlink (no response). But my RTS Oximo motors are also able to 'talk' with Telis.
Willem81
Good morning!
I have a Telis4 Remote to control my Somfy Roller shutter.
The RFlink recognizes the signals, see Debug log below.
When I press the button "Learn Switch" Domoticz learns the Signal. Then When I press Up or Down on the switch in Domoticz....... nothing happens
So it seems The RFlink is able to pick up the signal and learn it, but cannot send it out.
Any ideas what the cause might be?
Debug log:
Thank you very much in advance!
Debug log:
10;rfdebug=on;
20;06;RFDEBUG=ON;
20;00;Nodo RadioFrequencyLink - RFLink Gateway V1.1 - R41;
10;version;
20;01;VER=1.1;REV=41;BUILD=03;
20;02;RTS;ID=16b73c;SWITCH=01;CMD=UP;
20;03;RTS;ID=16b73c;SWITCH=01;CMD=DOWN;
20;04;RTS;ID=16b73c;SWITCH=01;CMD=DOWN;
20;05;RTS;ID=8b5b9e;SWITCH=01;CMD=STOP;
20;07;DEBUG;Pulses=90;Pulses(uSec)=4740,1200,1170,1200,1170,570,510,570,540,1200,1170,1200,510,570,510,570,1170,570,510,1230,1140,1200,510,570,510,570,510,570,1170,570,510,1230,1140,570,510,570,510,1200,510,570,1170,570,510,570,510,1200,1170,570,510,1200,510,570,510,570,1170,1200,1170,570,510,1200,510,570,1140,570,510,570,510,570,510,1200,510,570,510,570,510,570,510,570,510,570,510,570,510,570,510,570,510,570,510,6990;
20;08;RTS;ID=16b73c;SWITCH=01;CMD=DOWN;
20;09;DEBUG;Pulses=86;Pulses(uSec)=1410,2460,2370,2460,4680,1200,1170,1200,1170,570,510,570,510,1230,510,570,510,570,1170,1200,510,570,1170,570,510,570,540,1200,510,570,1170,1200,510,570,1170,570,510,570,510,570,510,570,510,570,510,1200,510,570,1170,1200,510,570,510,570,1170,570,510,1230,1140,570,510,570,510,570,510,1200,510,570,1170,570,510,1200,1170,1230,510,570,1140,1200,1170,1230,1140,1200,1170,1200,1170,6990;
20;0A;RTS;ID=16b73c;SWITCH=01;CMD=STOP;
20;0B;DEBUG;Pulses=82;Pulses(uSec)=1230,1230,1170,570,510,1230,1170,570,510,1200,1170,570,510,570,510,1230,510,570,1140,1200,510,570,1170,570,510,570,510,1200,510,570,1170,570,510,570,510,570,510,570,510,570,510,570,510,1230,1140,570,510,570,510,570,510,570,510,1230,1140,570,510,1200,1170,1200,1170,1230,1170,570,510,1230,1170,1230,510,570,1170,570,510,1230,510,570,1170,570,510,1230,480,6990;
20;0C;DEBUG;Pulses=84;Pulses(uSec)=570,1140,1080,1140,1110,540,510,1140,1170,570,510,1200,1170,570,510,570,510,1230,510,570,1170,1200,510,570,1170,570,510,570,510,1200,510,570,1170,570,510,570,510,570,510,570,510,570,540,570,510,1200,1170,570,540,570,510,570,510,570,510,1200,1170,570,510,1230,1170,1200,1170,1200,1170,570,510,1200,1170,1200,510,570,1170,570,510,1200,510,570,1170,570,510,1200,480,6990;
20;0D;RTS;ID=16b73c;SWITCH=01;CMD=UP;
20;0E;DEBUG;Pulses=82;Pulses(uSec)=3660,1200,1170,1200,1140,570,510,1230,1140,1200,510,570,1170,1230,510,570,510,570,510,570,510,570,510,570,510,570,1170,1200,510,570,510,570,510,570,510,570,1140,570,510,570,510,1200,510,570,1170,1200,510,570,510,570,1170,570,510,1200,1170,570,510,570,510,570,510,1200,510,570,1170,570,510,1200,1170,1200,510,570,1170,1200,1170,1200,1170,1200,1170,1200,1170,6990;
20;0F;RTS;ID=16b73c;SWITCH=01;CMD=STOP;
marmachine
- Domoticz version: 3.4834
Hi Willem,
I'm sort of struggling with the same thing, however i have a RFXCOM (RFXtrx433E), maybe this gives you some direction;
To send my Somfy screen Up/Down i had to use the RFXmngr software first to pair with the RTS motor of the screen.
Following the procedure to pair a second device (such as remote or a switch) to the RTS.
So far so good, i am able to send it up and down from the software right after the pairing was successfull.
Next step was (manually) adding a switch to Domoticz;
- Hardware: RFXCOM
- Switchtype: Blinds
- Type: RFY
- ID: XX XX XX (this is the device ID as set in the RFXmngr)
- Unit Code: XX (also as set in the RFXmngr)
Now i am able to send the screen Up/Down through Domoticz as well.
My current issue is that, since there is no feedback from the RTS motor about current position, Domoticz doesn't know the screen is already down when that's done by the remote outside Domoticz. I would like to catch such actions to trigger a "manual override" status to my automated steering script. However i have no idea how to catch the remote signal since it is not detected by the RFXCOM in the first place, however i actually have the same RFXCOM successfully paired to my screen!? I have a "Somfy - Telis4" remote to use for 4 screens. Anyone who could help me out?
I believe that the theory behind the Somfy remote is that, when pairing a remote with the RTS, a shared "key" is stored in both devices. Without this key, you won't be able to steer the RTS. I'm not sure, but i think that the device ID: XX XX XX (3x2 digits) represent the key.
For RFXCOM, see page 34 of the manual
Pairing a second device to Somfy RTS, see page 100 of this manual
- Hardware: RFXCOM
- Type: RFY
djgodlike
I paired the somfy screens from the RFLink loader (did it by adding 1 to the original code: "10;RTS;2c2a40;1;PAIR;" when code was 1c2a40).
Did get feedback from the screens and "OK" in logging screen.
The logged code from the remote: "20;02;RTS;ID=1c2a40;SWITCH=01;CMD=UP;"
Now i try to add a manual switch in Domoticz (Blinds, RFY and the same code with 1 added) but the switch won't work..
Can someone give me some advice?
I placed this message in another post aswell.
Aeon Labs Gen5 USB
Greenwave Powernode 6 NS310
2x Greenwave Powernode 1 NS310
Philips Hue
Logitech media Server
Plugwise Smile P1
Philips Hue
Plugwise Smile P1
Willem81
Hi all, thanks for the suggestions.
Unfortunately I do not get it to work
Anyone other suggestions? Otherwise maybe it woudl be best to buy a RFXTRX433E, but that would be a pity because I am very happy with the RFlink. Works on almost everything.
Willem81
I tried DJgodlikes method. That works. I can pair it using:
10;RTS;[UNIQUECODE];1;PAIR;
The Somfy motor confirms that it has been programmed in the right way. But then the "UP/DOWN" etc do not work. But now I am convinced that it should be able to work with RFlink
- Stuntteam
We will do some tests..
Willem81
Great! Thank you Stuntteam
supermat
I have made au tutorial :
https://matdomotique.wordpress.com/2016 ... -et-somfy/
I hope it help, but it's in french
djgodlike
I got the screens working with the RFLINK! Thanks to "supermat's" tutorial..
I had to factory reset my Somfy Oximo screens before i got it to work.
Aeon Labs Gen5 USB
Philips Hue
Plugwise Smile P1
Philips Hue
Plugwise Smile P1
Ruudvd
I also got it to work with r41 by following the tutorial (with google translate), for the id i had to use hex adresses 0-9 = normal ,10 = A, 11 = B etc.
rmss
Thank you for the great tutorial. I've got my blinds working from RF-Link loader with commands 10;RTS;0F0F0F;0412;0;DOWN; and 10;RTS;0F0F0F;0412;0;UP; but when I've add the blinds to Domoticz, nothing works.
Log shows that it's sending commands
2016-05-18 14:10:36.689 RFLink Sending: 10;RTS;0f0f0f;3;ON
2016-05-18 14:10:54.318 RFLink Sending: 10;RTS;0f0f0f;3;OFF
I've tried Blinds and Venetian blinds EU switch types.
Raspberry Pi 2 - RF-Link - Marmitek CM15PRO - Din rail dimmers & switches
SHadley1138
I have the exact same issue, I need up/down, but it sends open/close
piokuc
I have a question... Is RFlink works only with somfy TELIS 4 ? Because i want use my Somfy Smoove Origin RTS and with this not working.
I read this manual:
and start test on my somfy. But for me it not working.
Ok i connect my RFLink by USB to my PC. Run RFLink LOader and i have latest FW 42 and serial port logging ON.
When i do command
all my entry was blank
Then i start pair my remote rts SMOOVE ORIGIN from somfy
https://e-rolety.eu/userdata/gfx/30dbab ... ea634c.jpg
i send command
and then i press for about 3 secund button on remote to PROG.
On loader show example
then i again send command and now show me:
And RC is not 0412 as i send command but is 0413. I don again it with other address 2F2F2F and RC 0222 and after that in RFLink is save RC 0223. Always is RC one more than i send by command.
And my somfy didnt working when i send commacnd:
Also i try send
as i have save in RFLink on entry 3 but also not working.
Please help me. I am begginer.
I read this manual:
When i do command
10;RTSSHOW;Code: Select all
RTS Record: 0 Address: FFFFFF RC: FFFF
RTS Record: 1 Address: FFFFFF RC: FFFF
RTS Record: 2 Address: FFFFFF RC: FFFF
RTS Record: 3 Address: FFFFFF RC: FFFF
RTS Record: 4 Address: FFFFFF RC: FFFF
RTS Record: 5 Address: FFFFFF RC: FFFF
RTS Record: 6 Address: FFFFFF RC: FFFF
RTS Record: 7 Address: FFFFFF RC: FFFF
RTS Record: 8 Address: FFFFFF RC: FFFF
RTS Record: 9 Address: FFFFFF RC: FFFF
RTS Record: 10 Address: FFFFFF RC: FFFF
RTS Record: 11 Address: FFFFFF RC: FFFF
RTS Record: 12 Address: FFFFFF RC: FFFF
RTS Record: 13 Address: FFFFFF RC: FFFF
RTS Record: 14 Address: FFFFFF RC: FFFF
RTS Record: 15 Address: FFFFFF RC: FFFFhttps://e-rolety.eu/userdata/gfx/30dbab ... ea634c.jpg
i send command
10;RTS;0F0F0F;0412;3;PAIR;On loader show example
20;07;OK;Code: Select all
RTS Record: 3 Address: 0F0F0F RC: 0413
RTS Record: 15 Address: FFFFFF RC: FFFFAnd my somfy didnt working when i send commacnd:
10;RTS;0F0F0F;0412;0;STOP;Code: Select all
10;RTS;0F0F0F;0412;3;DOWN;
10;RTS;0F0F0F;0412;3;UP;
10;RTS;0F0F0F;0412;3;STOP;Please help me. I am begginer.
SHadley1138
Ive had exactly the same problem, I just can't get Somfy Rts to work. I've done exactly the same as you have described too
piokuc
Maybe support from RFLink can help us please?
And with what remote you try ? TELIS 4 or SMOOVE ORIGIN ?
SHadley1138
Telis
