Todays easy question (Solved)
Xroads
Post by Xroads »
I'm trying to get the lux value from some pirs, so i can use it as trigger.
Using this string
lux = tonumber(otherdevices_svalues[c],'Lux')
Where c is the name of the pir, and the sensor is named "GangLux", but never getting any data.
I'm 100% sure theres something wrong with the formatting of this string, but as a total newb I just can't see it :oops:
Raspberry pi 2
Razberry z-wave module with Fibaro dimmer, relay and pir and Dlink pir.
433mhz RFlink with 5 pcs. on/off switches
Xroads
Re: Todays easy question (Solved)
Post by Xroads »
This is the correct formatting.
lux = tonumber(otherdevices_svalues[c..'Lux'])
Raspberry pi 2
