Reading Lux sensor with Blocky
kritjuu
Post by kritjuu »
I have Aeotec Multisensor. I want to use the Lux sensor for closing the curtains when there is a lot of sunshine.
Is this possible with blocky editor, because I do not understand the LUA scripting language?
The Aeotec Lux sensor is in a utility device and is a purple utility block which means I can only use to check actual values.
I want to close the curtains when the lux sensor reads >1000. How can I fix this?. With blocky noting happens.
georgesattali
Re: Reading Lux sensor with Blocky
Post by georgesattali »
I think that it is not possible without lua.
Here an example to extract several values from a multi valued sensor :
Maybe you could try to create a "time" script :
- But a question, how is the curtains closing stopped ? is it automatic ?
commandArray = {}                      -- required
-- Barometre returns 5 values  - 5 times (.*)  only 4 ";"
sWeatherTemp, sWeatherHumidity, sWeatherUV, sWeatherPressure, sWeatherUV2
   = otherdevices_svalues["Météo Baromètre"]:match("(.*);(.*);(.*);(.*);(.*)")
-- print just prints in the Log
print("-- Irrigation ==> [Baromètre] - Temperature: " .. sWeatherTemp .. " ")
print("-- Irrigation ==> [Baromètre] - Humidity: " .. sWeatherHumidity .. " ")
print("-- Irrigation ==> [Baromètre] - UV: " .. sWeatherUV .. " ")
print("-- Irrigation ==> [Baromètre] - Pressure: " .. sWeatherPressure .. " ")
print("-- Irrigation ==> [Baromètre] - UV2: " .. sWeatherUV2 .. " ")
if sWeatherUV >= 1000 then
   commandArray["curtains"] = "On"         -- that's the blocky "Set curtains= On"
return commandArray                            -- required
kritjuu
Post by kritjuu »
Thank you for the answer. Yes the curtains stop automatically
Can you explain what a "time" script is?
georgesattali
It's a script called every minute. It means that every minute it will check visibility.
In this case, you may also use a "device" script that would be called each time visibility changes. Typically every 40 s in the case of a temperature, don't know for Lux sensor.
When you're in "Setup/Events", choose Lua instead of Blockly, choose "Time" instead of "All"
Bye,GD
