i have a problem, i installed in my peripherals domoticz the kodi media server with the ip adress i use for my kodi in windows.
this is the log i have :
2016-04-10 22:24:54.723 Kodi: Worker stopped...
2016-04-10 22:24:54.734 Kodi: Started
2016-04-10 22:26:52.597 Kodi: Worker stopped...
2016-04-10 22:26:59.313 Kodi: Started
2016-04-10 22:27:44.533 Kodi: Worker stopped...
2016-04-10 22:27:44.544 Kodi: Started
the problem is my switch domoticz is not displayed the status when i play a video in kody.
i use the default port 9090 for kodi
i turn off my windows firewall but nothing happens, any idea ?
thanks
Switch Kodi Domoticz
- Dnpwwo
Re: Switch Kodi Domoticz
bran2000
i use the URL, the step i did:
"if using the default port 9090, make the port -9090 and your log will be spammed with messages."
this the message in the log :
Kodi salon connect to "IP" failed connection refused
any idea what is it ?
- Dnpwwo
Connection refused would suggest that the Kodi is not configured to allow external control.
Did you follow these instructions http://www.domoticz.com/wiki/Kodi#Kodi_Settings?
bran2000
i ticked both
"Allow programs on this system to control Kodi" and "Allow programs on other systems to control Kodi"
same result, it's not working
bran2000
ok my problem was the Windows authentification, i removed the password at the login page so now my profile opens automatically without asking password.
- Dnpwwo
That's interesting.
Are Domoticz and the Kodi running on the same machine? Is Domoticz running as a service?
