MyDomoticz - Testers wanted!
Re: Testers wanted!
I have a login issue that I cannot seem to pass by:
After registering I was able to login to my.domoticz.com. I got an instance which didn't seem to by my own Domoticz, strange username, other Domoticz Version. I logged off, and logged in again. The instance is gone...
I now only get the following message:
"Enter your api data to your own Domoticz in order to use this service"
My api key is present in Domoticz, tried a couple of times re-entering it, also tried adding and removing spaces. It is correct and it's the only API key I have, the one that worked once.
The Instance ID I cannot change of course.
Password is correct, checked and double checked.
I also did all the checkbox combinations: (dis)allow sharing, (dis)allow apps etc.
I restarted Domoticz a few times, didn't help.
Upon logging into my.domoticz.com I only get the message above. The Domoticz log says:
"PROXY: Authenticate result: wrong password for apikey/instanceid combination."
This may be the case, but the info I have and the details I can change have been entered correclty. The login credentials seem to be messed up but I cannot delete my account either to re-register.
Any thoughts anyone?
Best, Tigo
Best, Tigo
- Domoticz version: 2022.2
Re: Testers wanted!
as of 8 april everything is down.
2016-04-08 02:53:02.345 Error: PROXY: Read failed, code = 335544539. Reconnecting: short read
2016-04-08 02:53:37.388 Error: PROXY: StartThread(): Exception: resolve: Host not found (authoritative)
i was about to show of the functionality to somebody else(bummer)
- HansieNL
Re: Testers wanted!
Strange... no problem here. Just logged in via 4G using Android 5.1 phone and Chrome.
Blah blah blah
Re: Testers wanted!
Same 2 me:
Registered new account:
After login: different user as owner of MyDomoticz Instance ID ????
Re: Testers wanted!
Hello!
I would like to provide own could access to Domoticz instances, preferably by hosting MyDomoticz.
According to the MyDomoticz-repo on github, the source will be published.
Do you know when it will happen or could you provide it to me by some direct means (pm with a link/...)
Best wishes,
Srdjan
Best wishes,
Srdjan
- epierre
Re: Testers wanted!
Hello Rene,
Could it be possible that MyDomoAtHome be accessible through MyDomoticz ?
Something like https://my.domoticz.com/my/xxxxxxxxxxxxxxxx/ISS/ would be very welcome and quite easy to do I think ?
Available to discuss it anytime (or on slack
Emmanuel
Emmanuel
ImperiHome & MyDomoAtHome on top of:
868.42Mhz - Vera Lite - Fibaro SS-101, S-211, K-101, FWP - Fortress SSA2
433Mhz - Cubie Domoticz + RFXtrx + Oregon || Foscam 9821W
2,4Ghz - Cubie MySensors Gateway + COV + TempHumidity + Pressure + WaterMeter
- Domoticz version: 3.5877
Re: Testers wanted!
One more vote for MyDomoAtHome, would be very very useful.
Btw, my instance is now red again, Last seen: 18-04-2016 00:30:28
Raspberry Pi 2 B - MySensors (dimmers, switches, motion, temperature, lux, humidity sensors)
zWave (220v switches)
various 433 via RFLink
- Domoticz version: V3.6028
Re: Testers wanted!
Here also I get the error: PROXY: Connect failed, reconnecting: Network is unreachable
I had the chance to use it before a week and it was excellent!
Question: Will mydomoticz interact with domoticz for android if I set the server ulr on mydomoticz?
edit: it just connected!
>>>> Google Home <<<<<
Re: Testers wanted!
I am still facing the same problem as I described above (April 8). Tried to create a different account but again I only get "Enter your api data to your own Domoticz in order to use this service". I am stuck at that point, the api and other details in domoticz are correct.
Is it possible to delete my account from the my.domoticz.com server? So I can try to make an account again, starting from a clean sheet? Or will my domoticz package remain registered anyway? I don't seem to have a way out here. And I am not the only one, if I understand Roelof (April 12) well.
Any help is much appreciated.
Tigo
Tigo
Re: Testers wanted!
I registered as beta user today (2016-04-24) and had my log filled with
After marking checkbox "Apps allowed" everything works fine. If this checkbox is required, maybe the wiki should be updated?
Btw, thanks for a great piece of software!
2016-04-24 15:05:19.613 Error: PROXY: Connect failed, reconnecting: Network is unreachable
Re: Testers wanted!
Hi.
I got instanceid "A48BD36E8ECA577" (I think that it is not correct because I'm not one has received it) in its API and the error "Authenticate result: wrong password for apikey / instanceid combination". Now I do not know how to change it...
If the same API used on another local server is instanceid is correct and the connection goes without problems.
Reinstallation does not solve the problem, instanceid remains.
Does anyone have a solution? I want to change instanceid.
Re: Testers wanted!
For me looks now the same as togi72 and lovikraba.
IN the alpha phase everytimg function well, but now I get same error message
Wrong password for apikey...
IS it possible that something is broken in the database???
Re: Testers wanted!
I still haven't got any confirmation emails yet. When I try to register again, I get a message saying I alrady am registered. And when I try to opt for a new password, I never recieve the new password email either.thorbj wrote:Hi, I tried to register, but I haven't recieved the confirmation email yet.
Maybe the email daemon is down?
2xRaspberry Pi Model 2 w/RaZberry z-wave chip (master/slave)|Fibaro Wall Plug|Fibaro Universal Dimmer 500W|Aeon Labs Multisensor|RFXtrx433E|Nexa WMR-1000|Nexa Pe-3|Nexa Remote|Nexa LGDR3500|Lightify Gateway|Lightify RGBW bulb
Re: Testers wanted!
I think we are going to need some feedback here from the administrators. I like to beta-test, like others. There seems to be a serious problem with the assigning of instance id/api/password. It has been reported a couple of times now. For these testers, me included, the login credentials are said to be invalid but we cannot change anything. Can anyone post an update about the culprit, or what seems to be the culprit? Then we can all think along and possibly help. Without any response to these issues so far, we're left in the dark... Even if the problem is still unclear, I'd still like to know.Gabe wrote:For me looks now the same as togi72 and lovikraba.
Cheers, Tigo
Re: Testers wanted!
right tigo72
Pls adminstrator give us some feedback so that we can help!
- Varazir
Re: Testers wanted!
Was there any plans for external apps to use this service?chimit wrote:This topic is about the about-to-be-released MyDomoticz service.
The MyDomoticz service allows for accessing Domoticz instances via the world wide web, without having the need of opening public external http ports of the Domoticz instance in question.
The service aims to be able to be managed as simple as possible, in order to be used by users who cannot (or don't want to) open external ports to the public Internet. It will be available in a future version of Domoticz.
The service is now being alpha-tested but before integrating the code in the Domoticz code base, it needs to be thoroughly tested. For this, we are looking for people that want to have a sneak preview of the service and are willing to provide feedback about bugs and user experience improvements.
This is your chance to contribute to the Domoticz open source project, even if you cannot code or translate or anything else. You just need to be using the service and see if it works.
The only thing required is be able to compile your own Domoticz from a Github branch that will be given to you.
In order to enter to this unique opportunity, please PM me.
Rene
Can it be used with 2 steps authentication or do I have to remove it for apps to work ?
Raspberry PI 2 with RaZberry Controller 2016 ZWave+ and CC2531(zigbee)
Several IKEA devices/z-wave devices
- chimit
- Domoticz version: master
Re: Testers wanted!
There's some major updates coming on, on the MyDomoticz service itself.srdjmark wrote:Hello!
Best wishes,
Srdjan
But other than that, due to limited time, we don't have a set date in the roadmap to release the sources.
- chimit
Re: Testers wanted!
There's no apps known to me that work yet with the MyDomoticz service. Besides writing a custom http handler for an app there's no support yet either on the service.Varazir wrote: Was there any plans for external apps to use this service?
- chimit
Re: Testers wanted!
Tigo, Gabe, Torbj, please pm me with your email address and or instance id's that won't work.
I'll look into the matter. Sorry for the delay to respond.
Re: Testers wanted!
For me the same.
After login, there is the message:
checked and double checked everything.
Joop.
For me the same.
Joop.
