RFXCOM USB or Serial Gateway for PIR Sensors
philkent
Post by philkent »
Just needing a bit of advice as after reading a lot of posts / topics am not sure what is best for my needs ...
I have indoors a couple of PIR sensors, along with some window / door ones that came with an alarm system that I never got round to installing.
I am now wanting to use them and integrate them with Domoticz instead.
What I am not sure about is whether I need to use a Serial Gateway from MySensors, or do I need to use a RFXCOM USB instead like this one below:
http://www.uk-automation.co.uk/rfxcom-rfxtrx433e/
Any help or advice on what would be better would be much appreciated.
Thanks.
Phil.
b_weijenberg
Re: RFXCOM USB or Serial Gateway for PIR Sensors
Post by b_weijenberg »
Which alarm system?
X10, Visonic 433MHz and Chuango are supported by the RFXtrx433E
RFX-433, RFX-433EMC, RFX-868
philkent
Post by philkent »
Thanks for the reply
I have just had a look, and the Alarm system is just called: Mobile Call GSM Alarm System, not sure how much that helps.
Picked it up on Ebay a couple of years back, but never got round to using / installing it. Was just planning now on using the PIR sensors that it came with, together with Domoticz, but was not sure how to integrate the sensors.
philkent
Post by philkent »
So has anyone else got any idea which way is best to go for me please?
You can reply with any suggestions as am new to all this and wanting to learn.
Cheers.
Phil.
manjh
Post by manjh »
Check the PIR sensors to see if they give you any information about frequency. If it says 433MHz then you have a good chance.
You'll need to get a bridge into USB to receive it.
Personally, I have an RFLink attached to my Domoticz Windows server through USB. Have several PIR sensors working.
Hans
philkent
Post by philkent »
OK Thanks manjh for that info. I will take a look at them and see.
So if so, is that RFXCOM USB adapter that I linked to in the first post what I will be needing?
Cheers.
manjh
Post by manjh »
either that, or the RFLink. Not sure, but I think there is a considerable difference in price.
Hans
deennoo
Re: RE: Re: RFXCOM USB or Serial Gateway for PIR Sensors
Post by deennoo »
manjh wrote:either that, or the RFLink. Not sure, but I think there is a considerable difference in price.
Yeap but if he already dont know how to open a box, take a pic, share it or use search on Google...not sûre that Rflink will help him.
His problem isn't a price one, but a curiosity one...
http://domo-attitude.fr
philkent
Post by philkent »
Hi - Yes, that is exactly right. I was just wanting to know which was the correct one to use. I do not mind investing in the RFXCOM USB if it would more than likely be the correct one for what I need.
Was not sure between that or building the gateway through mysensors.
From what I can gather from the responses, the RFXCOM would be the better option, am I right on that thinking?
manjh
Post by manjh »
As I understand it, they are functionally the same.
Hans
Mediacj
Post by Mediacj »
Functionally they are indeed the same, they both form an interface to Domoticz.
The difference is the way you connect your Rfxcom to Domoticz, with USB you connect it directly to your physically Domoticz server and with serial there is another system (second Pi or whatever) which sends the serial messages of Rfxcom to the Domoticz server over the network.
philkent
Post by philkent »
manjh wrote:As I understand it, they are functionally the same.
Mediacj wrote:Functionally they are indeed the same, they both form an interface to Domoticz.
Thanks for all the help and responses, appreciated, is a lot clearer now. I think I will more than likely go with the RFXCOM route, even though the cost is more, it seems like it would be better for me functionality-wise.
Cheers for all the help and feedback. Learning it all slowly, bit by bit. ;)
Shaggie_NB
Post by Shaggie_NB »
And still, you don't know if your alarm system is gone work with this solution... :lol:
Users browsing this forum: heggink and 1 guest
