Script to turn off panic mode if triggered for alarm.
ketra90
Domoticz version: 2284
Post by ketra90 »
Hello guys,
i thought i'd share a script i made for resetting panic mode of smoke detectors, i bet its kinda specific to my domoticz setup, but maybe this helps some ppl to make a better one.
#!/bin/bash
## Setting Variable's
Domoticz_IP=
Domoticz_Port=
# DO NOT EDIT BELOW THIS LINE
declare -a arr=(`curl 'http://'$Domoticz_IP':'$Domoticz_Port'/json.htm?type=devices' 2>/dev/null | jq '.result[] | select(.Type=="Security")' | jq '.idx'`)
for index in "${arr[@]}"
do
index="${index//\"}"
echo `curl 'http://'$Domoticz_IP':'$Domoticz_Port'/json.htm?type=command&param=resetsecuritystatus&idx='$index'&switchcmd=Normal' 2>/dev/null | jq -r .status`
done
Domoticz Setup:
RAZBERRY.
Win 2008 Server On ESX USB Connected RFXtrx433E.
all externaly secured with a Sophos UTM firewall.
3x kaku dimmers
1x benext dimmer
3x kaku motion sensors
Eneco Toon
Kaku doorbell
ketra90
Re: Script to turn off panic mode if triggered for alarm.
Post by ketra90 »
This is a script u need to execute within a switch, for example when the alarm is triggered u turn on a dummy switch, and then when this switch is turned off , the off action (this script) is executed
Domoticz Setup:
RAZBERRY.
3x kaku dimmers
1x benext dimmer
Eneco Toon
Kaku doorbell
Kroontje
Post by Kroontje »
Maybe a stupid question, ... but is it also possible to put smoke sensors (Fibaro) in panic mode so the siren can be used in an alarm system?
bran2000
Post by bran2000 »
when i execute the script : i have this error
ligne6: jq : commande introuvable
a problem with jq any idea ?
ketra90
Post by ketra90 »
Kroontje wrote:Maybe a stupid question, ... but is it also possible to put smoke sensors (Fibaro) in panic mode so the siren can be used in an alarm system?
sorry for late answer, at this point i havent found a option to do so.
Domoticz Setup:
RAZBERRY.
3x kaku dimmers
1x benext dimmer
Eneco Toon
Kaku doorbell
ketra90
Post by ketra90 »
bran2000 wrote:Hi,
JQ isnt installed by default on the system, if you are using the domoticz sdcard or a debian linux, u can use apt-get install jq to install it
Domoticz Setup:
RAZBERRY.
3x kaku dimmers
1x benext dimmer
Eneco Toon
Kaku doorbell
Kouseri
Post by Kouseri »
Resetting of panic mode of smoke detectors can be done also from lua with following piece of code
ipAddress = "192.168.1.2" --IP address of the Domoticz server
port = "8080" --Port of the Domoticz server
IDX = "34" --IDX value of the alarm siren
commandArray["OpenURL"]="http://"..ipAddress..":"..port.."/json.htm?type=command&param=resetsecuritystatus&idx="..IDX.."&switchcmd=Normal"
