I am new to domoticz. Now I have added some light switches i would like to add our doorbell.
Info Model PO-1413 Envivo. Frequency 433.92
Now I like to know how to add this doorbell. Learning does not give any results.
Should I use the Byron protocol or is there another way to het the correct parameters.
add doorbell
- leecollings
Re: add doorbell
Turn them all on, then make sure 'Accept new hardware devices' in Settings is checked. Then press the doorbell And see if it shows up in Devices, or check the logs to see if it's being recognised.
Re: add doorbell
Thnx for your answer,however as said I am a newbie.
Please tell me WHERE should i turn WHAT on.
I cannot find anything that looks like activating protocols.
Heisenberg
Re: add doorbell
I think he means turn on all the protocols of the rfxtrx transceiver. This can be found under Hardware
Raspberry Pi Type B
Raspberry Pi Type B2
RFXCOMtrx433e
RFXCOMtrx433e
Re: add doorbell
I use the RFlink, does that make any difference on where to find the protocols ?
Under hardware I cannot find anything to switch on/off protocols . I suppose that you don't mean "add hardware" ?
Dirk
Re: add doorbell
I had the same problem and posted the answer in viewtopic.php?f=31&t=11952&p=157193#p157193
Users browsing this forum: Google [Bot], jvdz and 1 guest
