Hy everybody,
I'm an absolute beginner in Domoticz, but so far all went well.
I've installed the Domoticz on my raspberry pi which is connected over LAN to my router. I acces the main page of Domoticz via Chrome via my laptop, normally connected to the router via wifi.
I've added several sensors via a RFX433 usb sensor, set up the standard layout, no problems.
But, I would like to experiment with custom frontpages. When I type from my windows laptop the ip adres of the raspberry I get the Domoticz main page, but when I like to acces the frontpage.html, I get all kinds of problems. In first I tried via port 8080, no acces, then I noticed in Domoticz that port 6144 is used, but again no succes.
I tried to add this port to my ziggo router, but still no acces. Can somebody help me with this?
Thanks in advance,
Bas
Access frontpage via network
BasvdLinde
woody4165
Re: Access frontpage via network
I can access via MyDomoticz (just replace the "#/Dashboard" with "frontpage.html") or via DDNS defined in my router.
The only thing is that in both cases I don't devices value on frontpage, but only from teh Domoticz standard Dashboard, Devices and so on.
BasvdLinde
Oke, got it, quite simple, instead of /#/Dashboard /#/Frontpage, all working now.
woody4165
Are you getting devices values?
I'm not and don't understand why.
