I bought 2 domitech lightbulbs (ZE27EU) and included them in domoticz via aeon-labs usb stick on raspberry.
The bulbs are not recognized by Domoticz though. I'm running the latest stable version of Domoticz. On Github I found an updated version of the openzwave lib. Is it possible to update only the openzwave lib, without updating Domoticz to a beta version and how is this done?
And when updated, do I need to exclude and included the devices to get them recognized?
I also ordered an Forest curtain, not found in the openzwave lib, but I found another xml config file on pepper1.net. Is it possible to implement this file into openzwave?
Support domitech bulb and Forest curtain
Re: Support domitech bulb and Forest curtain
I'm also wondering if it's just a matter of adding the xml file in the right directory to get it working? If so I will pull the trigger on a few of these.
Sent from my SM-G925K using Tapatalk
Domoticz running on Windows Server 2008 in VMware (ESXi), UZB1 stick, 3x FIBARO FGD212 Dimmer, 1x FIBARO RGBW Controller FGRGBWM-441, 2x FIBARO FGMS001 Motion Sensor and 2x Popp 009006 Plug-in Switch
You can add devices to your own installation at any time by adding an xml with the devices settings. But for everyone else to benefit, it would be best if you could submit your changes to OZW. You can read more about it here:
https://github.com/OpenZWave/open-zwave ... ng-Devices
Thanks for the answers. I read about other users with the Forest curtains but they probably didn't send the xml file to openzwave.I don't have the curtain installed yet and was wondering if it was possible to include a xml file on forehand.
The Domitech bulb is listed in the openzwave plugins but not on my installation of Domoticz. The bulb is working (sort of), I need to switch on polling to get the right dimming value after switching on or off. It is then updated with a rather long delay.
- Target OS: -
The Domitech ZE27EU light bulb is supported as of today. I was really happy to discover that as I just got mine
It seems to be responding fast (within about 2 seconds) but I have not tested alot. I have not activated polling or changed any default values.
It is not supported in my setup so I entered the xml file manually. After that I restarted Domoticz but the device is not recognized yet.
Do I need to include it again or should the device be recognized automatic?
Users browsing this forum: Bing [Bot] and 0 guests
