LightwaveRF contact switch
433Mhz opensource Receiver & Transmitter.
Truff
Post by Truff »
I have a lightwaveRF contact switch which is recognised by RFLink and Domoticz, and in the Domoticz log I can see it creating an identical log entry for opening and closing.
But in the actual log for the switch this is just showing as status OFF for the opening/closing events so the contact switch never appears to be triggered. In order for something to visibly occur when the contact opens would I need to write some sort of script ?
simonrg
Domoticz version: 3.8807
Re: LightwaveRF contact switch
Post by simonrg »
Truff wrote:But in the actual log for the switch this is just showing as status OFF for the opening/closing events so the contact switch never appears to be triggered. In order for something to visibly occur when the contact opens would I need to write some sort of script ?
I thought these sent both off and on signal. Which LightwaveRF part number is it?
Even if a switch is already off, and it sends another off, it will trigger an event as devicechanged in Lua or the off action will occur. You should see this is the text log for the switch, but the graph will a flat line.
Raspberry Pi 2 B - 2A@5V PSU - Raspbian + Domoticz + RFXtrx(89), LightwaveRF House(dimmers, sockets, wireless/mood switches), Owl CM113, 4 LaCross Temp / Humidity Sensors, 4 Siemens PIR, Smappee, Solaredge, ESP8266
Stuntteam
Post by Stuntteam »
It sounds like an issue we just fixed.. check your PM.
Truff
Post by Truff »
Just a quick note to say the LightwaveRF contact switch is now working great after assistance from Stuntteam and now its correctly logging the opening and closing of the contacts.
I've also got 5 LightwaveRF Dimmer switches working around the house now using RFLink so its all looking very good indeed.
ivanzaster
Post by ivanzaster »
Please could you send the solution
I got the same problem with the Lightwaverf sensor.
It works perfect and sent notifications but suddenly only sent off signals
Thanks in advance
SHadley1138
Post by SHadley1138 »
i wonder if you could tell me how you paired the lightwaverf contact switch, as its driving me nuts.....
thanks in advance
Pi, RFLink
